MP3 player for ES350
Hi.
What, if any, are the requirements on using an MP3 player in my ES350? Will any MP3 player suffice, what connector is required, etc?
Thanks,
SammyS
Thanks,
SammyS
Easy as cake.
Go on down to yer local Radio Shack and ask for a piece of wire with male 3.5mm stereo mini's on both ends. One end into the headphone jack of your iPod or other device, other end into the jack that is found in the center console under the arm rest. It is toward the front of the car. Set yer radio on Aux and knock yourself out. Adjust the volume on your portable device for best fidelity (1/4 to 1/2 volume on some, 3/4 on others) and then control the volume with the cars volume ****. If ya wanna be really cool get a car power adapter while you are there too.
See...slice of pie!
As to the other part of your question, as long as there is a headphone output on your device you are good to go.
See...slice of pie!
kmy
10-17-11 11:59 AM
