Going to bigger wheels and wider tires?
The info about tire sensor I got from the place where I did my tinting. They told me about changing tires/wheels on other Lexus cars, than when people sell their car and put original tires/wheels back, they forget about the sensor. Would like to confirm this. Anybody? *edit* sounds like tnfan already explained this above
BTW, talked to a few of my buddies at work who are "car experts", they all agree that going to a bigger/wider tire will not improve performance/handling dramatically. Will have to do the whole strut bar changes and lowering springs for a stiffer handling. Of course, all that will affect the soft ride which I really enjoy with Lexus!!! Might have to re-think the whole tire upgrade strategy, might not even worth wasting $2k for all that...
Thank you for the reply and your expert advice. What kind of springs can you recommend? Are those supposed to be a shorter version of what we have already in ES350 or just a stiffer kind? What about tire/wheel size, can you give any recommendations please? How would you determine the maximum allowable width? From what I've seen on TireRack site, 19" will make tire depth way too low. I would think 18" be an ideal upgrade in here?
No way, forget about IS. Its too small especially for a baby seat in the back (and who knows, maybe for two sometimes in a future ) Don't get me wrong, I absolutely love the ride of this car, no complains here from excessive luxury I'm just used to a better road grip and sportier suspension with my previous Altima SE. I kind of decided right now that no alteration of suspention going to be done, and the only change could be with wheels/tires. If I'm going to invest $2k for a set of four, its not going to be done just for looks but also for performance improvement. Thinking out loud, 19" or 20" (if I find such a low profile tires for 20") will ruin the ride quality completely. Which leaves me with 18", and the improvement in there is a wider tire which can add to the road noise, but ultimately improve the road grip and handling at turns. I'm not planning to race this car, just an everyday cornering through jug-handles (a typical NJ way of left turn from the right lane to go around to intersection), or just going around the ramp on/off expressway. The car feels too soft on these turns. Also, benefit of wider tires in wet and snow weather is a plus.
Also, interesting to learn about that sensor inside. So, its attached to the wheel, not the tire. How does the info from the sensor gets transmitted, since I assume there is no wires running inside? If its a wireless sensor/transmitter, wouldn't it require a battery replacement?
Technically tnfan was partially correct; he had stated that new sensors must be purchased when buy new/replacement tires...which I said in a previous post was a bit hard to accept. I can see buying new sensors if you choose to buy another set of wheels/tires and don't want to go through the trouble of swapping out the sensors from your original wheels, but I can't see the requirement of buying new sensors solely because you're having new tires installed.
This is a link to a TireRack article about TPM's:
http://www.tirerack.com/tires/tirete....jsp?techid=44
1. people actually read the manuals??... O_o.....
2. in my opinion.. wider tires would help with traction... which i believe would quiet that massive tire squeal you get from hard turns...
3. set of sprigns would just ruin your nice smooth ride
4. if you want major performance upgrade i suggest LSD ( limited slip differential) which would help on hard turns and would cancel out that massive under steer that you always get from a Front wheel drive
5. as far as going "Baller" status on the ES350.... dont... if you wanted that you shoulda gotten a cadillac or something....
EyesOnly
Wheels, Tires & Brakes Forum
11-24-05 02:32 AM
