Are We Tired Of Tires?
I sure hope not.
First off, let's just agree that "all season" tires are, at best, a compromise of just about everything dynamic in a car. Let's then add to the mix that the tires supplied with the majority of new ES' are far from the best of this already motley crew. The Michelin MXV's are terribly ordinary tires and they really don't do anything particularly well, except perhaps, lighten your wallet if you have to replace one.
So I think we can take it as a given that you'd be insane not to run "summer tires" if you live in any area that does not get a significant amount of snow.
If (as I do) you live in an area that does get snow, unless you want to switch out your tires every winter with "snow tires" (a huge pain in the a** that few of us want to be bothered with) we are stuck with the far more mediocre A/S'. When I owned my 2000 ES 300 I eventually replaced the OEM Michelin MXV's with Michelin Pilot Exalto A/S at a much cheaper price. What a difference! The car handled much more sharply, turn in was quicker and there was decidedly less body lean. Here's a Tire Rack survey of high performance A/S' if you want more information.
http://www.tirerack.com/tires/survey....jsp?type=HPAS
Anyone else have any experience with other high performance A/S' ?
The ones on our Camry XLE were Michelin Energy MXV4 Plus. They're relatively low rolling resistance, fairly quiet, smooth riding and quite good grip in dry and wet conditions. I feel that they're so-so in the snow. I couldn't find any place near my area that sold the TripleTreds so we were sorta forced to replace the OEM tyres with another set of MXV4 Plus when they wore out.
Hmm, Exalto A/S does have a high rating and customer satisfaction. Too bad they only go as high as 17". I'm seriously considering in a spring/summer time to go with 18" (225/45-18) and A/S high performance tires. It makes no sense to do it now cause of our East Coast winters and all the afterward potholes; don't want any extra wear/tear and re-alignment in a spring time again
I do enjoy a soft comfy ride with a default tires/wheels, but the turn handling on ramps, etc. is a joke. And, I already said that before: No, I don't want a sport performance car or GS/IS alternative. I absolutely love ES350 and just want to enhance the driving experience
BTW, since I don't have manual and tire brochure handy in front of me, what is our tire's load index for ES350?
It already rides a bit stiffly (with ironically no perceptible improvement in handling....go figure!?) so be ready for some jolts my friend.
I think this is another case of "ride quality" being a relative term. I guess it all depends what you are comparing this ride to. To my personal taste, the ride is too soft. I agree that going with a wider (225 vs 215) and lower profile (45 vs 55) tires will compromise a little (again a relative term) the ride quality: noisier and stiffer, but it should not compromise the compliance since a relative ratio of going up in radius and down in profile should stay relatively the same. The only problem here is that I can not try before I buy for a comparison. I don't want to do this for a show-off, but honestly want to improve the handling and performance of the ride.
twister, I wish you would go ahead and do this so you could give us a first hand report. I am with you on the desire for a bit better handling. And I bet the lower, wider profile would be an improvement as well.
Don't forget pics!
Don't forget pics!
You the man!!!
Seriously, I can't wait for your report also. If it markedly improves performance without degrading the ride, I think you may be on to something here.
Do the wheel wells have enough clearance for the 225 width?
Yokohama Avid V4s is what I'm replacing the OEM tires on my ES350 when the stockers give out...like around 25-30k. I had these on my Maxima, replacing a set of the Falken Ziex 512s, and the Yoko's did a very nice job. Very well rated on TireRack, and a sporty look to them too. Also quite decent in snow.
twister,
I believe many are waiting for somebody to upgrade the wheels & tires and report on it. Only "lbeal" has 18" wheels on his ES350 and reported no difference vs 17" wheels. I would like to see pics as well and see how it looks from behind.
By the way, tirerack.com already has ES350 in their upgrade garage.
cyke
cyke
twister,
cyke
cyke
Actually, seeing the wheel combinations mounted I think I may be partial to the AR2. Damn, there are some really awesome looking rims out there that really preserve the classy look of the car but make it look infintely sportier.
Now if we can just find a way to make it handle sportier!
Depends which Pilot model doesn't it? My friend's HX (215/55R17) isn't that great... I think it's called the HX.. the one on the TSX anyway. Also, the Pilot Premacy on the Euro/Japan Prius (195/55R16) aren't the grippiest either so I'm assuming you're talking about a better model than the two mentioned above? Or am I just talking nonsense?
