Bluetooth phone questions
1. The bluetooth phone appears to periodically lose my home phone number in Speed Dial 1. It is replaced by my cell phone which is another entry in the phone book. I was under the impression that the Speed Dial was only updated in the car. Phone changes do not affect the speed dial numbers. I haven't made any changes the home number and my cell phone number. Suggestions?
2. When pairing a second bluetooth phone, and there is a second phone in the car, does it prompt you to which phone you want to use? If there is only one, I assume it will use the one it finds.
Reponse to 1):
I just figured out today that Speed Dial 1 screen actually only has space for 5 numbers. Item number 6 in the bottom right, holds the number of the last number you have dialed and is not programmable. On Speed Dial 2 and 3 screens, all 6 slots are available. Therefore, there are a total of 17 speed dial entries that can be programmed, rather than the 18 you would expect.
For number 2):
The selected phone is maintained as the phone that will be paired even if there are multiple phones that have been paired in the car. It appears to only look for the selected phone. If it is not in the car, it does not switch to another paired phone.
misterk
08-28-07 05:46 PM
Mousse
12-13-06 09:17 AM
