Wish me luck guys!
Wish me luck guys!
I will be picking up 2 ES350s tomorrow and I have my checklist of things to look for in hand.
1. Build date
2. Wind noise @ speed
3. Tranny issues
4. Noisy valves
Anything else? I hope I am doing the right thing, I almost feel like I am looking at an oncoming train and running towards it.
1. Build date
3. Tranny issues
4. Noisy valves
1. Build date
3. Tranny issues
4. Noisy valves
1. Build date
3. Tranny issues
4. Noisy valves
The only other things I'd check is:
wipers on high while quickly repeating misting feature or using a garden hose on windshield to see if they are rocking your vehicle as they should not do that...
and when driving on a straightaway let go of steering wheel (briefly) to see if it is strongly veering right as that will get on your nerves when driving and placing resistance clockwise on your hands on many roads. Seems they can fix that if you push them on the subject.
You might be the most well prepared new car purchaser they will have experienced.
Good luck to you.
P.S. When checking for this valve issue, be sure you drive the car right away and that it registered cold when you started it. If it is present it will be umistakable and heard as a knocking/tapping noise on top of otherwise normal cold engine noise and/or on top of revving as you accelerate down the road.
I'd check for engine vibration. Drive the car and when stopped at a light with the trans in gear, just put your arm on the centre armrest. If the steering, console or engine vibration bug you now, its only going to get worse.
Wind Noise is an easy one to check for. Drive at 60-80mph with AC and audio off and if its there, you'll hear it coming from the front windows only, probably on both sides. You will probably find a difference between the two vehicles too in this regard. If you even remotely think you've got an issue, jump into their test RX350 vehicle afterwards and take that out and do the same thing. The RX has more road noise at speed for sure, but the windows seem to be built like vaults and seal perfectly IMO.
Wanderer is spot on with the notice vibration, I stopped complaining about it, but the morning of the first full day I owned my car, there was that valve knocking/tapping and there was vibration in steering column you can feel holding steering wheel. Also floorboards, arm rests and the like. If it does this, RUN, don't walk, away from that one.
You will notice this as most intense at stop lights, signs and when parking the car before turning it off after driving it.
It is as though the cheap motel at beach magic fingers vibration option has had a quarter thrown in it and it starts, not that pronounced, but enough of an analogy to give you an idea.
Robert, do keep us posted. I picked up a June build SGM PP and it has the wind noise. Some of the lining on top of the car isn't fixed tightly, so I went to get it done. Now, the wind noise is kept at a minimum and it doesnt bother me that much. Fortunate to have avoided the trans issues (though its not the smoothest of all) and the valve issues.
Picked up an 8/08 build and it doesn't have any strange noises, vibrations or wind noise. Fortunately it rained tonight so I had a chance to take it out and try out the wipers. I noticed a little movement of the car at a standstill but I would be able to feel that in other cars as well. These wiper arms are pretty big and they are moving pretty fast so a little movement is unavoidable. Overall, it seems that I made out ok.
I wish you guys the best of luck with your issues and hope to god that I don't have the same issues!
JohnsRX
RX - 1st Gen (1999-2003)
10-24-02 10:17 PM
