ES 350 Strutural integrity compromised & rattles (thread updated with resolution)
#47
My car has one Rattle in the back parcel post self, every time when I go over a bump it goes bong-g-g-g-g-g-g-g-g-g-ing. When I bought the car on day 2 of ownerships the drivers side rear fender popped out does that classify as a rattle of the third kind?
#48
oso...
That does not sound good at all that the fender popped out and you have the back area rattle. I hope NGG reads your description to give his opinion.
Is your back glass kind of----for lack of better term--- loose? As in can you make a fist and using the bottom part of your fist lightly tap on the middle of the glass about 6 inches up from bottom of glass and hear a rattling metal--glass like combo sound?
Make an appointment and get that looked into.
#49
You may wish to read Post # 21 in this forum for a possible solution to your parcel shelf area rattle. Suggest you do this prior to dealer visit. Hope this helps.
NGG
#50
oso...
banging fist? interesting. Does that make the same sound as my video below?
#51
I have the UL and the rear window sounds tight. I quickly read through post #21 “NGG” yes my car has had many problems since day 2 of ownership (on-going). Finally in early December it was approved for replacement. I’ve requested a 01/07 build replacement car as I believe that’s the very best I can do to protect myself from another trans issue.
CdnSaab95
ES - 6th Gen (2013-2018)
43
05-20-19 02:57 AM
