Nav. System Data Disc
Can anyone tell me the latest version of the Navigation System Data Base. My March build date has a .05.1 disc. I recently had Nav. system up-graded for the improved VR functions. Now VR function works pretty good but when Nav. screen is displayed the tip of red indicator/pointer does not line up with street intersections. (Seems to indicate actual location is several hundred feet before you get to intersection when you are actually in intersection.
The more I work with the Nav. system the more I believe the original Gen 05.1 data disc is not totally compatable with the improved VR unit. For the first several blocks the position indicator shows the car running parallel to the street and always a couple of hundred feet from the street. Position shown after stablization is always short of intersection. Question? Without the VR improvement do owners with either Gen 5 or Gen 6 units have units that provide exact intersection locations when parked in intersections?
This is one more reason I'm glad I didn't do this. I had it scheduled for a couple weeks ago and backed out the day before when I read that it would disable the Volume override sequence. What is up with that?
