List of current ES350 TSIBs
#91
SB date: 4 Feb 2009
Applicability: 2007 ES350 produced before JTHBJ46G#72178510 VIN
Issue: Squeaking noise from engine compartment when engine running
Repair: Add pulley cover plates (washers) behind both #2 idlers
#92
SB date: 11 March 2009
Applicability: 2007, 2008, 2009 ES350, made before JTHBJ46G#82242436 VIN
Issue: Hear a rubbing noise from rear of vehicle, due to rocker panel molding protector coming loose
Repair: Secure the molding
#93
SB date: 13 May 2008
Applicability: 2007, 2008 ES350 made before JTHBJ46G#82196161 VIN
Issue: Feel a thunk/jolt/shudder when lightly accelerating after transmission upshifts around the following speeds: 26 mph - 4th gear, 36 mph - 5th gear, 44 mph - 6th gear
Repair: Replace the torque converter (a component of the transmission)
Note: See also L-SB-0027-09
#94
SB date: 17 March 2009
Issue: All the usual things this car's transmission is famous for: shift flare (slipping when upshifting causing engine to rev freely for a moment), harsh downshift on reacceleration, "jerk" feeling on reacceleration. It appears Toyota has redesigned the transmission & torque converter to fix this problem. Sadly, it seems dealer service department lackeys are trained to say these characteristics are "normal" or "could not be duplicated".
Repair: Replace the transmission (including the torque converter). Then, update the firmware.
#95
SB date: 19 Mar 2009
Issue: Your $40K luxury sedan sounds like a diesel truck when idling. Engine cylinder cover area makes a ticking/clicking noise. The malfunction lamp on the dashboard may be illuminated.
Repair: Replace various VVT-i components (oil pressure actuated devices that adjust valve timing based on computer inputs). This is a complex repair that requires opening up the engine.
#96
SB date: 24 March 2009
Issue: Outgoing phone volume is too low or distorted
Repair: Reconfigure system to increase outgoing call volume
Note: Not a warranty issue; dealer may charge for this service
#97
I have serious problem, I just get ES 350 2009 Ultra-Luxury, 10 spoke -wheels 215/55 R17, my car is not soft at all, I feel any smallest bump on the road.
When I took a drive test on ES-350 it was unbelievable soft driving. Now absolutely
different.
What do you think guys, may be because Ultra-luxury different suspension, wheels or something else.
different.
#98
different.
different.
#100
I am in a similar situation as that described by nkahovka. Just bought 2009 ES350.
The car is not soft at all, we feel any smallest bump on the road. When we took a drive test on ES-350 (at 3 different dealers) it was unbelievable soft driving. Now absolutely
different. I did adjust the tire pressure (it was at 40 PSI) to 30 PSI. Slightly better ride now - but nowhere near the ride experienced with the other cars at the 3 different dealers. Tires are Michelin MXV5.
Any suggestion? Have there been problems with the shocks?
Any suggestion are welcome.
AZ
AZ
#101
Does anyone know any other website besides www.lexustsb.com which has the list of all the current TSIB ? I dont think it is very update.
For example, I can not find L-SB-0118-08 which is for the fix for the wind noise.
#103
https://www.clublexus.com/forums/mai...-for-free.html
this is the website that I found the TSIBs. a member posting it recently in the maintenance section
#104
there is an active voluntary recall for the 2007 ES350 for the variable valve timing oil hose 9LH:LSC 9LH. the expiration date for this is March 13, 2013. dealer should replace this free of charge.
