View Poll Results: What octane grade of gas do you fill your ES with?
87 Octane
79
26.87%
89 Octane
46
15.65%
91 Octane
86
29.25%
93+ Octane
83
28.23%
Voters: 294. You may not vote on this poll
The mother of all grade of gas debates for ES350 (merged threads)
#106
Call your dealer and find out what viscosity oil they use. If the factory fill was a 5w20 and the dealer uses 5w30 or 10w30, you will see a decrease in mpg. If you want the best mileage use a synthetic 5w20 or 0w20 and you'll see an improvement right away. I have seen enough Used Oil Analysis to know that 5w20 or 0w20 is not too thin a viscosity.
P.S. If it makes you feel better. My 2006 ES only averages 21.5mpg so far.
The owners manual only specs 5w30, but actually suggests using a higher viscosity oil for high speed or extreme load conditions although it doesn't specify a grade. I would not be apposed to using a 5w20. I'd probably start with RedLine and as you mention King do a couple of UOAs to ensure wear is OK. When you look at RL viscosity numbers its almost a 5w30. It would be intersting to see how viscosity affects milage. It might have more of an affect than octane rating of the fuel.
#107
#108
My IL dealer put in 5w30 when my car was in for the 5,000 mile service in October.
#109
They used 5w30 because that's what the manufacturer recommends.
#110
There is a revised bulletin by toyota to use 5w20 in most cars produced after a certain date. Pheonix, has a thread about this and the ES350 is included. I would use 5w20 especially during winter to have better start-up protection due to a thinner oil.
#111
https://www.clublexus.com/forums/sho...d.php?t=232049
#112
King - Is the TSB you are referencing in the thread below? I don't see the 2GR-FE (ES 350/Camry V-6) engine listed. What am I missing? It also doesn't refernce Lexus models.
#114
After the first few tanks of premium, I switched to mid grade (89) and noticed no changes. Have been using the regular (87) unleaded since about Oct. without any noticable drop in performance. She runs smooth and strong.
#115
Here in No Cal, on the Peninsula, I need to fill up every 10 - 14 days and I'm still getting about 26 mpg overall. I use top grade Shell because that is what is at the corner. Right now it is $3.45 a gallon for self serve (mind checking the oil there fella?). About $50.00 for a fill (more like a top off since I never let it get too low). No more steak, Top Raman anybody?
When I first started driving I could get low test in LA for 0.199 per gallon.
#116
On the more serious side, the MPG has got to be one of the better aspects of this vehicle. 272hp and great mileage to boot! Its nice to get over 400 miles on a tank of gas and if I ever took it across the desert, I'm sure I could make it to 500 miles.
