Possible "fix" to wind noise on highway
Bob,
I ended up turning in my 07/06 build loaner for a 09/06 build before I had a chance to look at the 07/06 for this issue. However, I did look at the 09/06 loaner and it has the goop, a silverish color on my gold colored loaner. The 07/06 build, the 09/06 build and my 10/06 build do not seem to have much difference in terms on road noise. The o7/06 had Bridgestone tires and both the 09/06 and my 10/06 have Michelins. I've also seen Toyos.
From a wind noise perspective, seeing we are talking about noise, my car seems to be the best of the bunch. Interestingly, the 09/06 is clearly the worst, and I now truly understand the wind noise complaints I have read about.
Seeker
Seeker
It's more or less a 1 foot deep and length of car swath of the stuff from front wheel area to rear wheel area each side of car with those larger plugs sort of in the midline of it.
When you have real good light check it out and see though I know it is a pain to get down and look under there. The bare metal is easy to spot, or was on my former car, it just looks like aluminum.
I guess it was a bit dark outside when I last checked so I didn't see it when I posted previously. I actually brought my car into the garage and jacked it up high enough to get underneath with a flashlight.
Yah, you're right - upon closer inspeciton (and removal of a bunch of mud), I did notice the black stuff you are speaking of. I didn't pay much attention to that before albeit I've been under the car several times in the past to change the oil, and even check for those gaskets.
You should try to take her off-roading less, so there is less mud buildup and you can answer our questions quicker in the future
Bob,
Seeker
Seeker
We can assume that several of the 09/06 builds have this stuff applied under there.
Now if some with older builds would look for it and report we will know more.
I know for certain my 06/06 did not have it as I spent too much time under there.
I suspect some with older builds who do not like road noise they feel is present also do not have this stuff applied. My current with this stuff has less of it but it also has far better door alignment than former which is what I thought was the reason for improvement.
As for turning the larger plugs right side up and wind noise, I don't think it did anything at all but also will say the goop applied, which oversprayed into plug recess, is uneven and the seal of plugs is not as good as if it were not in those plug recess areas.
You have to take one out to see, but the right side up is where the flange or lip of the plug is outside the car not pushed up through hole. You'll see the metal is hole punched and as well there is recess surrounding the hole punch to accept the flange...that is unless it is coated with the black goop...LOL...it still is recessed but somewhat uneven surface due to the goop. On my former car putting the plugs in right side up would have fit better as it had none of that stuff applied and no overspray coating recess.
If you look at the 2 smaller ones right near back of front wheels you'll see the difference, they are put it in the way I would have thought the larger should be and how they are now on my newer car since I turned them all over.
My 08/06 build had the wind noise problem starting ~40mph. Sounded like the driver window wasn't completely closed.
When I went in for the 5K service, I talked to them about it. They test drove the car and agreed it wasn't right and ordered a seal "B Pillar outside moulding".
This week they installed the seal, then test drove the car after installing it and said there was still wind noise evident even below 40mph. They took the door apart and "increased tension of weatherstrip". I believe the weatherstrip is feltlike strips that contact the glass inside the door.
There is a dramatic difference now, on my car they have solved the problem.
I had earlier checked the underside of the car, all of the plugs were in place and my car has the black stuff in a strip between front and rear wheels.
My car doesn't rattle, doesn't have the trans flare and although it did have the deisel tapping during the first week or so, that is completely gone.
My only remaining issue is the seat belt buzzer. They've tried twice to shut it off but it still hounds us. I've tried using the instructions posted somewhere on this forum and I couldn't shut it off either. It's a minor irritant since we always buckle, but don't need to be told that by a box!
That is good news that they took it seriously and did the work they did.
If I understand right, it sounds like they used the lower portion of glass typically unexposed in door panel and placed it under increased pressure by adding felt or something to force the upper-visible glass to press against it's seal with more force. Sounds plausible to me it would net a benefit.
If time and circumstance permit can you confirm exactly what portion was involved in the tensioning or convey their steps involved description that they may give you if asked?
<stuff deleted for brevity>
Re: seat belt buzzer--ask your service advisor to do some more research, or else find another dealership employing a more-knowledgeable one; my local service advisor initially hadn't heard about the ability to "deprogram" the seat belt chime but was eventually able to find the instructions on how to do so.
I was wrong about the seat belt buzzer, they did turn it off, I guess something else was causing a chime a couple times right after the service.
I just read the post about adding felt inside the upper seal, I think what they did to my car inside the door has the same affect, but coming at it from a different angle, it slightly repositions the glass into better contact with the rubber seals.
Before this service, the worst noise in my car was coming from right around/above my ear.
ES350Bob
ES - 5th Gen (2007-2012)
09-09-06 04:46 AM
