XM radio problem
I just would like to know if anyone else with XM radio in their ES 350 has had this happen to them.When I started the car in the morning,I then turned on the XM radio.The audio coming from the xm was intermitant and garbled.This went on for 10 seconds and then nothing , no audio.The read out for the artist and song were there, but no audio.The am and fm worked fine. But no xm.But when I stopped the car and turned it off. I then turned the car back on.I then turned the xm back on and it worked fine.I contacted the Lexus service department.I explained the problem to the service manager.He told me this will happen to xm sometimes.He told me that when you turn the car off this will reset the xm part of the radio.Now this problem with no audio on the xm radio has happened to me twice.I have had to car since july 19th. Has anyone else had this happened to them.
I'll suspect your radio works the same as the JBL system, someone can confirm what I think it might be.
I had on occasion listened to my ipod and then listened to CD or the radio before going back to the ipod... When I would change the mode sometimes, I would get no sound, the disc played the radio station tuned in but nothing! And the ipod was just cranking less than a minute ago!
Turns out, the radio recalls set volume levels for various functions... I never hooked the XM up to my JBL system, but the radio and CD worked off the same volume control and the Aux (or ipod) had it's own volume control, I bet the XM tuner had it's own volume as well. So what happened was this...
1. I turned down the radio to 0 when I parked the car...
2. I went to work all day
3. I got in the car and switched to Aux right away and jammed out
4. 2-3 days later I decided I wanted to listen to the radio
5. I was like WTF is wrong with my radio?
Check it out... My new car also recalls volume levels among "modes."
My XM Roady in another car requires a power cycle at times to recover the audio. Display is ok at this time, and I suspect that the processor in it gets confused and requires a reboot to recover. I haven't noticed a similar problem with our XM radio in the Lexus yet, but I wouldn't be surprised that the same thing can happen.
This seems to be a relatively common problem with XM. It's only happened to me once. Other's on the IS forum have had more occurences of this issue. Haven't heard of any permanent 'fix' other than the 'power off/reboot' one.
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
