ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Aaarrrggghhh!!!
Old 01-13-07, 09:21 AM
ES350Bob
ES350Bob's Avatar
Originally Posted by e-man
Here's a little known fact. The later, more advanced Neanderthal man was actually the first to use bricks. It was the earlier, less sophisticated Cro-Magnon man that used string and *****.
Sorry to get off topic, Dreyfus.
Wow, that is a very little known "fact"
No bother though, it would be whichever relied mostly on knuckle walking that would have the easier go of sliding things around on the ground since they were low to the ground as it were.
Aside from that, attaching a ball by string to the ceiling would require mastery of walking upright, balance issues you know.
Old 01-13-07, 09:24 AM
Larry ES
Larry ES's Avatar
Oh man. Sorry to hear that. This is my biggest nightmare. You'll get it fixed and it'll be as good as new in no time. Here's what I do to prevent this from happening. Next time you pull your car into the garage, after making sure that the car is in the correct spot, put a brick on the ground in front of one of your front wheels so that whenever you pull in you'll always hit the brick and know that you're in the right spot.
Sorry again.
e
Similiar to the brick approach, I purchased a Parking Target from http://www.ipiproducts.com/parkingtarget/. Surprisingly, it works very well and it doesn't move either (a month in use now).
Old 01-17-07, 11:20 AM
weinrdog
weinrdog's Avatar
I really wouldn't recommend doing this. Those sensors are positioned that low for a reason. If you have small kids that aren't walking yet, I would definitely recommend AGAINST doing this. Just the other day, there was a story on the news about someone backing up into their 18 month old on the driveway. This had nothing to do with the sensors because the car was in the driveway, but I'd rather have a scratched bumper than something much worse.
No reason you can't mount two sets of sensors on the door. Depends on if the sensor is normally open or normally closed if you would need to mount in series or in parallel. That way both would have to be clear for the door to lower.
JessTX706
12-20-15 08:40 PM
Brabusx2
05-15-13 10:07 PM
ChitChat
RX - 3rd Gen (2010-2015)
08-10-11 07:02 PM
imherenow
06-19-11 01:27 PM
litesoarer
04-03-08 06:05 PM
Quick Reply: Aaarrrggghhh!!!
