ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Clunk from rear of vehicle when accelerating from a stop
Old 10-13-07, 11:15 PM
  #31
350Dave
350Dave's Avatar
The full tank noise does not bother me, just as long as I keep getting 25+ MPG I could not care less...
Old 10-16-07, 12:30 PM
  #32
toneman
toneman's Avatar
Originally Posted by ChipM
I'm having a similar problem on an RX330. I seem to recall a noise like this with newer BMW's being ralated to pressurization of the fuel tank/fuel system (on OBD-II cars, i.e. post '96, the fuel system is pressurized in order to be able to detect leaks. This is also why you get a CE light for not tightening the gas cap). So, i think it has something to do with suction collapsing the gas tank, and the "POP" is the tank opening back up when suction is released.
What i can't remember is why there is too much suction, and how to fix it.
Maybe I'm not following the logic completely, but if the above is indeed the case...then wouldn't it make that noise only once per full tank? On my ES w/ a full tank of gas, I can repeat the clunk at will, except if I accelerate very gently/slowly from a stop...at least until the gas tank goes below roughly 3/4 full or so.
Old 10-16-07, 01:39 PM
  #33
ChipM
ChipM's Avatar
Not necessarily once per tank; believe it has something to do with pressurization so it happens throughout driving cycle. However, mine is not necessarily "at will" on the RX
Old 12-18-09, 06:45 PM
  #34
micosan
micosan's Avatar
Was there a final answer to this question?
Old 12-19-09, 04:02 AM
  #35
garsarno
garsarno's Avatar
Never heard any clunk from the rear gas tank area, whether full or not.
Old 12-19-09, 07:50 AM
  #36
zhivuyatut
zhivuyatut's Avatar
Mine is definitely making this thump. I was dismissing it as some cargo dislodging and hitting trunk walls, before realizing I don't have any cargo. I did not pay much attention to this before, but now that I know it would be haunting me.
I did not get the correlation with full/empty gas tank yet. Simple sloshing of gas in the tank would not do this. But it is conceivable that a wave of gasoline in the tank hits some baffle or rushes into some tight corner, making a hydraulic shock.
I am curious too if somebody did get Lexus to acknowledge the issue. None of my previous vehicles did this.
Old 12-19-09, 12:35 PM
  #37
garsarno
garsarno's Avatar
Could a baffle be loose?
Old 10-09-10, 04:52 AM
  #38
pestleman0
pestleman0's Avatar
I'm experiencing the clunk.
Old 01-02-11, 12:55 AM
  #39
jinnjia
jinnjia's Avatar
same here, I have the exact same noise, rather than "clunk" I think more of a "thump".....
Old 01-02-11, 07:46 PM
  #40
kewl
kewl's Avatar
This is an old issue, first ID'ed back in 2007. It is, as someone said earlier, likely the float hitting the top of the tank when the tank is full. Dealer's everywhere say it is normal and there is no fix for it...as of now, and my guess is there never will be one from Lexus. It is nothing serious...just another noise source - at least while the tank is near full. Once you use a bit of fuel it will go away until the next fillup.
Old 01-03-11, 07:24 AM
  #41
micosan
micosan's Avatar
This noise is really annoying. My dealer also said it was normal. I am hoping someone is able to definitively determine the cause of this noise. Meanwhile I was looking at suspension components which I thought might cause the noise. Hopefully the attached images might provide some insights to knowledgeable members who could guide us to possible solution if these components are the cause of the clunking noise. The gaps shown in the images are created when the car was lifted at the left rear jack position.
I am guessing there may be some nose diving during a stop causing the rear of the car frame to ride up and cause a gap between the frame and rear suspension cross-member support, and also between the cross-member and the stabilizer bar support bracket. Once the car starts moving forward the rear of the car frame sits back down closing all the gaps which causes the clunking noise.
It would be great to hear from others about my speculation and possible solutions. Thanks
Suspension Component link http://www.trademotion.com/partlocat...layCatalogid=0
Attached Thumbnails Clunk from rear of vehicle when accelerating from a stop-rearsuspcomp.gif   Clunk from rear of vehicle when accelerating from a stop-crossmemb1.jpg   Clunk from rear of vehicle when accelerating from a stop-p1010523.jpg   Clunk from rear of vehicle when accelerating from a stop-p1010524.jpg
Old 02-07-11, 10:37 AM
  #42
Jimbo68
Jimbo68's Avatar
micosan, thanks for the work on the suspension. I have the same noise, sometimes pronounced. Don't know for sure, but it may well be gas movement in the tank when almost full. It isn't a float, that not the way it works. I think it may be a baffle design flaw that doesn't address the forward and backward movement of the gas. I will be checking on the noise as the tank gets somewhat less full.
Old 02-08-11, 11:00 AM
  #43
Jimbo68
Jimbo68's Avatar
It's definitely a full gas tank issue. The thump in my car went away after a couple gallons of gas had been used up. A poorly designed baffle is more than likely the reason. Just my two cents.
Old 02-10-11, 07:50 PM
  #44
overclock
overclock's Avatar
I just turn up the radio and I don't hear anything.
taojonz
31
09-17-22 04:33 PM
Kylexus789
ES - 7th Gen (2019-present)
04-13-19 09:06 AM
billm555
10-27-18 07:29 AM
Hitcher
10-18-08 08:21 AM
miked808
07-18-08 08:04 PM
Quick Reply: Clunk from rear of vehicle when accelerating from a stop
