View Poll Results: 23mpg As Is Or 21mpg With INSTANT Throttle Response...Is The Trade Worth It?
YES!!!!!!!!!!
15
60.00%
No, it would be nice, but not at 2mpg less efficiency
12.00%
I have no idea what you people are talking about, my car is perfect
28.00%
Voters: 25. You may not vote on this poll
Would You Accept 2 MPG less efficiency To Get A Tranny That Responded IMMEDIATELY?
OK, this is a pretty straightforward question. Many have suggested that the dreadful "disconnect" between engine and tranny is a conscious design decision engineered to produce better gas mileage.
If this is so then it should be pretty easy to design an "override button" that restores complete and instant communication between engine and tranny. The price would be the loss of a couple of mpg of efficiency.
Assuming that your overall mpg would drop from let's say 23mpg (my overall average) to 21 mpg, would you find this an acceptable price to pay to have instant throttle response?
So you'd be paying an extra $3.50 penalty per tank of gas.
filling up once per week, 52x 3.5 = $182 per year penalty.
choices choices....
Drive like a granny....... or pay $182......
hmmmmm
choices choices....
hmmmmm
i cant imagine the choice to be so simple, as there is more to it than gas efficiency. The overall design is involved, so the quick response would require the sacrifice of other amenities, perhaps smoothness and cushiness of the ride. IMHO.
Not necessarily so mon ami!
Lexus brass reads this forum regularly (as I'm sure you are aware) and one would hope that they both recognize and respect the desires of their buying public.
"Toyota has made its surge on producing the most fuel efficient cars in class…and a software reflash would most likely reduce EPA mileage estimate on the Avalon, Camry and ES350 by 4mpg."
Above quote taken from site listed below:
http://www.fourwheeldrift.wordpress....ting-problems/
If the transmission responded immediately, the car would use LESS gas, not more.
First of all, I don't agree with your premise here. How does an inefficient transmission response SAVE fuel? When you have a situation, on the ES and some of the older IS300 models where, at acceleration from a rolling low-speed situation, the engine RPM's run away for several seconds while the car itself does not keep up, that is NOT saving gas. On the contrary, that is USING unnecessary gas because the engine is turning unnecessary RPM's ( at a rich air-fuel mixture for acceleration) while the car itself is not responding much.
What kind of place do you think this is anyway?
You do not have to lose mpg in order to not have hesitation, other manufacturers somehow pull off providing vehicles without the hesitation and still get good fuel economy. This is software related and is correctable.
I would love to take this opportunity to interject, "If you're willing to pay a price for better transmissin performance, stop *****ing & drop the valve body. Then send it to a transmission shop for a valve body mod. Most popular/trusted on the Toyota transmissions in general, and the ONLY trusted scource of hi-po FWD Toyota transmissions. Is IPT".
And if all you want is control over transmission shifting. All you have to do is ground the ECU outputs for the different control solenoids through relays, or switches with a 10w resistor to ground & then run the shift solenoids yourself via whatever means you want.
A $4 switch from radioshack if you want...
Work on getting the valve body pressure up during shifting... The pressure control solenoid. Trace the signal at your varrying throttle positions to find out how the computer opens the valve more to allow more pressure. Then do the same thing there.
Ground the ECU output to a 10w resistor & control it yourself.
How's a dealer going to spot a spring in a valvebody? LoL!
And why is it rediculous? Tons of other cars have it done when new.
Nothing is stopping anybody from doing it. It's not an expencive proceedure. Infact, on most automatic transmissions. The valve body itself is one of the best price to accelleration deals going.
