Horsepower boost
The U660E is THAT bad.
If the Camry's max speed is indeed 162 mph, I would think that the speed rating of the Camry's factory tires needs to be Z-rated since theoretically it would otherwise not be safe to run V-rated tires on a car that is capable of hitting such speeds; is this indeed the case?
I'm a bit skeptical of the "claimed" (by who--Toyota? Some auto magazine?) 162 mph limit of the Camry, since--and I'm saying this based on the assumption that the max displayed speed on the V6 Camry speedo is the same as that of the ES--the ES speedo's max speed display on the speedo is 160...
The factory Michelins (on my ES) are 92V...meaning they're capable of sustaining a maximum speed of 149 mph. Makes sense, given the ES's max speed of 137...IOW, H-rated tires would not be appropriate for it.
C/D TEST RESULTS:
Zero to 60 mph: 5.8 sec
Zero to 100 mph: 14.5 sec
Zero to 130 mph: 31.0 sec
Street start, 5–60 mph: 6.1 sec
Standing ¼-mile: 14.3 sec @ 99 mph
Top speed (governor limited): 145 mph
Braking, 70–0 mph: 170 ft
Roadholding, 300-ft-dia skidpad: 0.81 g
Again, I think the different trim levels may have different governed speeds... C&D tested the XLE not the SE and the SE has a special underbody aero package to increase stability at high speeds. My speedo clearly wound up past 145MPH and I never felt any hint the car hit a governor. The SE has H rated tires, but it wouldn't be the first time an mfg put subpar tires on a "capable" car... Not everyone will try to test those limits. I'm beginning to think there is indeed a difference between the LE & XLE and the SE for governed speed.
onsknht--FWIW I wasn't disputing that you were able to get your Camry to go faster than 145 mph; I was just questioning the (not "your") claim that the V6 Camry had a 162 mph speed limiter. If indeed certain Camrys have such a high limiter...I find it interesting that Toyota can't trust us w/ inputting nav/phone-related stuff while driving, even at slow speeds...yet apparently think that we're capable enough to pilot a vehicle at such high--and illegal--speeds.
I do this this tho - It makes no sense at all to mod a brand new car (especially a FWD near luxury/family car) that's under warranty to gain more performance. You'd void the warranty and then have people starting a thread about their dealer who won't replace their blown engine under warranty.
The only time the warranty is voided is when your modifications expressly, and directly cause a mechanical failure. It's not the rule of thumb, is Federal Government warranty law.
Yall are also forgetting that it's the Camry SE, which has (since 1994) had an unmarked option for a different final drive ratio, among other minor changes.
The ES350 looses:
18.27bhp @ 70mph
53.26bhp @ 100mph
117.01bhp @ 130mph
218.14bhp @ 160mph
There is no voided warranty by modifying the engine, or drivetrain.
Let me know how that works out for you, when you take your modified engine and/or drivetrain, with a mechanical failure, into the dealership for warranty work.
^^^ It's the Magnuson Moss Act (I mighta spelled that worng?) ^^^
Pheonix is right on the drag issue... this is why when they put a turbonormalizer or a bigger engine in an aircraft (like a C182) the plane only gets a few knots more speed at best... In the case of a turbonormalizer, the plane gets a lot more speed at higher altitude because it couldn't really fly there previously, but at lower levels like 2500ft ASL, very little speed increase because of the drag.
Tony, sorry not being defensive, I'm just confused, I thought all internals were the same? Whatever the case, the diff between Nav and the Speed Governor is the Nav can be used while driving legally... Get into an accident as a result of the Nav while driving in the confines of the speed limit and all other laws --->>> Toyota is liable. Get into an accident at 162 MPH on any road in the US and you were braking the law --->>> Toyota is not liable, just as they aren't liable for you wrecking the car when drunk. My only explaination for the differences in the speed governor is a "package thing" on the SE timed with the introduction of the Camry in NASCAR... It's that little "ringer" Toyota added to get some "street cred" and it's on their "hot body."
If you say turbonormalizer one more time I'm going to hit you with something.
It's a run of the mill turbocharger that has it's wastegate pinned to hold boost at seal level. It's a completely idiotic term, and really just a completely stupid idea. If you're going to run FI, then run FI. Don't stop at sea level atmosphere where the system won't even pay for it's own weight.
AFA isntallation in a car, there is no point. @ WOT your engine get's under 5 in/hg of vaccuum from ambient pressure.
fyi it takes over 27.xx in/hg to = 1psi. So you can see there is very, very little differance you'd be gaining. About the differance from going from a stock air filter to a bull**** K&N filter.
The internals partaining what to what? The engine is identical, the transmission is identical. The final drive ratio in the differential can be different.
I think it's acedemic anyway... Toyota hasn't made a Camry/ES/Avalon since 1991 that couldn't creep to 135-140mph in good mechanical condition.
For just some quick math, I would esimate the ES to be able to do 144 in a somewhat timely fashion, and creep up to around a 149mph terminal velocity. I do not believe higher than that is possible given any track length through the automatic. Pulling the 6200rpm peak horsepower the car would be doing 185mph in 5th, 219mph in 6th. Not gunna happen. 165mph would be about 4650rpm in 6th (never going to happen). @ 5500rpm the engine has about 260bhp, 5500rpm in 5th is about 165mph. The problem is 260bhp is not NEARLY enough power to pull that fast. You'd bearly pull 150mhp at all @ that power levels.
So I'ma just put down 150mph maximum speed for the 3.5L Camry platform right now bone stock in my opinion. It's too far of a stretch to believe faster for me.
I forgot who it was! Very good, it is the Magnuson Moss Act.
I wasn't trying to be one. I was just saying you'd be taking a BIG risk to expect a dealer to honor your new car warranty if you modified the engine or drivetrain and had a problem. That much I do know. Personally I wouldn't be willing to take that risk on a $35K-$45K new car. Maybe you would, but not me.
Super Moderator
Oh yeah, the moral of the story, never try to push your car back down the track unless you are truly out of gas.
