Results from latest TSB transmission flash
#31
I have a 10/06 build date - purchased in November last year
Acceptable may be a relative term - I think its "more acceptable" than the harsh cold start flare but having a flare at all when in normal operation is not acceptable to me.
Originally Posted by robob2
Would you classify it as aceptable?
#32
I test drove a new ES today. No hesitation, good downshift and no flaring. Salesperson acknowledges this has been a problem, but
states this issue is "fixed". Are you all buying
that these recently produced cars are "fixed"?
#33
If the salesperson claims it is fixed, have them give you a 30 day money back clause if the tranny flares. Bet they won't sign it.
#34
I had my car in for the 15k service Wed and reported what happened to me. They reflashed the transmission control module per TSIB TC005-07.
I didn't have the 3-4 shift flare but reported another issue with downshifting on hard acceleration. They kept the car overnight. Mine is an 08/06 build.
Haven't driven much yet, but it does seem to shift slightly differently than before.
#35
While the "fix" ought to change some shift behavior (it's trying to fix the flare after all), is it possible that reportedly different shifting behavior is due to "learning"? Does re-programming the transmission reset the learning? Over time will the shifting behavior aproach what it was right before the flash?
#36
Not just yet. I will have to see results from the owners who have the problem. If they solved the problem then they should be fixing all the ones that flare. When (if) I see that then I will believe it
#37
I promise I'm not trying to be funny...
#38
#39
Remember folks the Es350 and Camry V6 transaxles DO NOT LEARN, they have AI - Artificial Intelligence... This as the copyrighted name implies, means that the transmission adapts to "current" inputs.
think about it....
I mean how annoying would it be to have your car remember your wife's driving habits over your own?
think about it....
#40
Below is a quote from the service manual.
CAUTION:
After the transaxle compensation code, be sure
to perform a road test to allow TCM to learn.
2. PERFORM ROAD TEST TO ALLOW TCM TO LEARN
NOTICE:
Perform the following procedures while strictly
observing all traffic laws and speed limits.
(a) From a standstill, achieve highest possible speed
with the accelerator pedal opened 15% or less.
Keep the accelerator pedal angle steady while
driving the vehicle.
(b) Repeat the previous step until shift shock no longer
occurs.
(c) From a standstill, achieve highest possible speed
with the accelerator pedal opened 25% or more.
(d) Repeat the previous step until shift shock no longer
occurs.
The compensation codes referred to are unique to each tranaxle and are related to the tolerances of the individual parts in that particular unit. Further, these codes are also long-term adaptive to compensate for normal wear-in of the transaxle with time and mileage.
#41
Just thinking out loud: tranny re-flash is nothing but a new firmware code to control shifting. The "learning" previous to re-flash is nothing but a bunch of data points collected from your everyday driving and stored in some separate memory location. Those data points are useless because they were based on previous shifting algorithm. So, I assume with re-flash everything going to be reset (like that Man in Black movie ). In theory, the current shifting behavior is due to a wrong firmware code to begin with. So, if they are going to change the code, it should change the behavior. Again, this is just a theory. In practice, we have to wait and see. It would be interested to see someone who developed a flare at 1k-2k, got a re-flash, and than report what happened after 1k-2k of driving with a new firmware. Of course, if you go right back to flaring, all the bets are off. Otherwise, we can see if anything has been fixed and how does the new learning curve works. I would not be surprised if Lexus engineers themselves are "testing" this code to see how it behaves over the time, and those of you who are receiving these re-flashes are nothing but guinea pigs. Again, this is just my humble opinion while speaking out loud
Bob
#42
While I agree with onsknht that our tranmissions are adaptive over the short term to the current driving style of the operator (nothing new...many electronically controlled transmissions have had this for years), there is a "Learning" operation referred to in the U660E Automatic Transaxle service manual that is required to be performed by the tech after certain repairs. For instance, it was specified in the failed Valve Body replacement TSB, as some may recall.
CAUTION:
NOTICE:
occurs.
occurs.
CAUTION:
NOTICE:
occurs.
occurs.
I just want fellas to know they can drive their car anyway they want and for the most part it'll never "learn" their driving habits.
#43
is it possible that even though the camry and es350 share the same engine and transmission, i thought the ECU updates between the two vehicles would be differenet. correct me if i am wrong, but i thought the gearing was a little different between the two vechiles. maybe hence the difference in results??
just a thought... thanks....
#44
is it possible that even though the camry and es350 share the same engine and transmission, i thought the ECU updates between the two vehicles would be differenet. correct me if i am wrong, but i thought the gearing was a little different between the two vechiles. maybe hence the difference in results??....
As we all know, the Camry is rated 268HP on regular gas and the ES at 272HP on premium. The cars are very similar in size and weight. Both of these vehicles contain a separate electronic control unit for the U660E Transaxle, referred to as a TCU (Tranmission Control Unit) which is linked to the primary ECU by computer bus. Both controllers have their own flash memory and thus can be independently updated.
My best guess is the the TCU coding would be the same in both vehicles but I can't confirm that.
#45
Come on folks, ah guinea pigs, post up!
