Bluetooth with call waiting
I was wondering if anyone else has been having the same problem with the bluetooth? I should also mention it is with the navigation system.
Whenever I get another call, while I am on one, the system will allow me to pick it up. However, when I do it works fine until the other party hangs up. Once the other caller hangs up, it kicks me off both calls.
Has anyone experienced the same problem and if so, a fix?
Also, I do dial numbers using my phone's keypad while driving, since you can't use the touchscreen while you are moving.
If you are able to click over and use the call waiting feature using your phone's keypad I must have a setting wrong. Everytime I do it works fine, but when either party hangs up (even though I am continuing one call), it kicks me off the bluetooth without hanging up the call. I guess I need to look at my settings.
Do you also use the Razor phone with t-mobile? I am wondering if it is a Razor issue. I have heard others with the same problem and they were using the razor phone.
colforbin
ES - 6th Gen (2013-2018)
14
08-04-14 10:14 AM
daned
02-26-07 09:31 AM
