10K Service
What is a good price for the 10K service? In Orlando they want $209 with rotating, balancing and changing the cabin filter. Is this average?
Welcome to the club. I'm assuming your username is the color of your car, and if so, a double welcome since there are very few members with that color. I love it! ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
The price sound's much too high!
In the first place, you DON'T have to rebalance tires unless you feel a vibration in the front end. Just rotate them. I also think that the main 10k service should be oil/filter change, and check fluid levels. I wouldn't bother changing the cabin filter, unless you have a foul smell coming from your a/c vents.
Remember, you're the boss, so tell them what you want done and then ask the price. A lot of things that they tell you are necessary generally aren't, and you can have these simple service procedures done for much less(and as well), from private service stations.
I now am just shy of 15K and will rotate the tires then. Price for an oil change and tire rotation/balance was just over $100.
OR, you can go to a Toyota dealer and pay $19.95 for an oil change. The Camry V6 is the same engine
