K&N Air Filter on ES350? anyone?
I had just picked up a K&N air filter from local auto shop. I am just wondering has anyone tried this on ES350 already?
( I haven't install it yet. Don't have time until Sunday afternoon@@)
A BIG waste of time!! What's the reason....to save money on filter replacements....or to screw up an otherwise good system that was designed to work well, and efficiently? The only difference in performance will be in your head. My suggestion......forget it!
Do you have any actual proof that a correctly-installed and properly-maintained K&N air filter was responsible for ruining the intake system of a Lexus ES 350 (I'm assuming that such a filter exists for it)?
Now, I'm not saying that the K&N filter is necessarily superior to the OEM in all aspects...but please don't go around insinuating to others that products such as the K&N air filter are completely bunk; after all, it's not as if it's one of them Tornado fuel saver products...
I've used K&N air filters in the past and found absolutely NO increases in efficiency, either in better gas mileage or acceleration! All I found was it turned out to be more of a PITA than it was worth.
BTW: I'm not insinuating.....I'm just stating a fact as I have found it!!
It looks like you're trying to start a war....but it says it all here in your above quote.
The way you criticize the K&N air filter product, I'd almost assume you think it no better than snake-oil products such as the Tornado...
