Tire pressure check
Tire pressure check
I was browsing through my manual last night and noticed that it indicated a tire pressure button around the dashboard but could not find it.
Is this an option ?
Is this an option ?
It's under the dash near the edge of the plastic face to the right of the steering wheel. Two black buttons, easilly seen if you stick your head down there.
It is my understanding that one of those black buttons under the dash is the tire pressure RESET switch. I assume that the button is depressed to end the visual alarm display on the left side of the dash when one or more tires require added air.
Is there a visual display that actually shows the amount of air pressure in each tire? My former Infiniti M45 had such a display. I found it most useful.
The button under the dash to the right of the steering wheel is used to initialize the TPMS. Check page 299 of your owner's manual. I don't believe there is any way to cancel the dash warning light other than correcting the condition causing the light.
The ES350 only tells you that a tire including the spare is low but gives no indication of which tire it is.
There is a second switch to register a second set of tires with pressure sensors. It is well hidden below the dash and glove box.
Dave Mac
Dave Mac
Begood9394
11-01-17 07:55 PM
