Brake pedal is stiff
Without touching the brake at all, press the Start/Stop button for one time to get the ACC mode (radio on, engine and dash are still off)... Then press and keep pressing the start/stop button for about 10~15 seconds and your engine will crank... No need to toch the brake at all ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
A side note though is a cylinder losing vacuum/pressure is not something to delay in getting addressed, ASAP with that.
Yes, if you are having problems with a 'stiff' brake pedal, it needs to be taken to the dealer. There have been notes in this months Di-Tech notes of issues with this. Who knows whats coming on it, but right now it is a small known issue with the boosters, and potentially the master cylinder. I have not seen a vehicle with this issue, but it is noted.
My recommendation is that any time you have problems with the the power braking system, take it to the dealer. It is a safety concern that needs to be addressed immediately.
Glad to see they fixed it for you.
the above is why you are a valuable contributor here.
I stopped at saying ASAP and was going to add wait till onepoint sees how casual folks are about this, he is going to have a fit and insist it be looked at right away....
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
If this is a sign of a more serious issue, I'll take it in.
One, so even if the brakes are fine when the motor is on, I should still take it in? I get the stiff pedal when the motor is off and I am trying to start the car. Also, this only happens about 30% to 40% of the time.
You know, its hard to say if its serious or not, but you know what they say, "better safe than sorry."
I would take it in and let them take a look at it. Im not saying this is the same concern as the RX330's because I simply do not know, but I do know we had some boosters fail out of no where. If you are having signs of problems, it really should be addressed. Just drop it off, grab a loaner, and let them poke around a little.
Its not like you are going to totally loose your brakes, but there are some specially situations when you really need the power assist.
Tantrix
03-16-15 08:38 PM
