fog lights
Does anyone have instructions on how to replace the bulbs in the fogs? The manual saids to call your dealership, I don't think that is necessary just to change a 9006 type bulb.
Pretty easy to replace the fog light bulbs - here's how I did it:
1) Remove clips from under the front bumpers that hold the splash shield under the car's hood - there's six I believe (dont remember for sure)
2) remove both left and right side shields
3) twist off and replace just light headlight bulb
I replaced mine with 9006 2500K yellow Nokya bulbs
Slightly OT but sorta related to your "call your dealership" comment--I guess Lexus doesn't want you to change the oil in your ES 350 either, as the owner's manual (IIRC--someone correct me if I'm wrong here) doesn't explain at all as to how to remove the oil filter canister.
skperformance
47
12-12-18 12:03 AM
