How can I change my Headlight bulbs?
Thank you very much for looking. I am currently in a dilemma. I need to change the low beam bulb on my 07' ES350 but dont know how. I tried doing it earlier today, and was able to actually get to the bulb, but was not able to remove it from the socket. Does anyone know if you have to turn in clockwise or counter clockwise, or just pull it straight out in order to take out the bulb? The car currently has the H7 bulb. Thank you
while bulbs may not be covered on the full bumper to bumper, they should be covered for one year...check with your dealer. If you are changing to a different color HID bulb, you can look at the new bulb and by the locations of the stops cast in the plastic, you can judge which direction to turn them. From the best of my recollection, all bulbs bayonette in right and loose left.
jashtiani
11-10-15 06:50 PM
ThermonMer
11-12-11 01:29 PM
