List of exterior light bulb codes
This is a minor issue. I like to keep a list of all the exterior light bulb codes so I can order them all at once. I do premptive maintenance such as changing the battery every 2-3 years instead of waiting for problems and replacing all exterior bulbs (except LED and HID) every two years to avoid chasing the inevitable random peppering and discovering of burned out bulbs. I checked the online owners manual and didn't find the codes anywhere. Does anyone know where these are published (if anywhere)?
Thanks
Thanks
If no one knows, just go to your local auto parts store and ask them. Whenever I replace bulbs, I just go to whichever auto parts store is convenient and ask them which one I need. It's all on their computers.
Here's a list I found...
2008 LEXUS ES350 (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D4S
High beam headlamp
9005
Parking light
2825
Front turn signal
992 (7440A)
Rear turn signal
992 (7440A)
Tail light
7443
Stop light
7443
High mount stop light
Assembly
Fog/Driving light
9006
License plate
2825
Back up light
921
Front sidemarker
2825
Rear sidemarker
194
Step/Courtesy light
2825
Trunk/Cargo area
DE3021
Low beam headlamp
HID-D4S
High beam headlamp
9005
Parking light
2825
Front turn signal
992 (7440A)
Rear turn signal
992 (7440A)
Tail light
7443
Stop light
7443
Assembly
Fog/Driving light
9006
License plate
2825
Back up light
921
Front sidemarker
2825
Rear sidemarker
194
Step/Courtesy light
2825
Trunk/Cargo area
DE3021
Guest
Posts: n/a
http://www.sylvania.com/ConsumerProd...RG-Results.htm
Low beam headlamp
HID-D4S
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
992 (7440A)
Rear turn signal
992 (7440A)
Tail light
7443
Stop light
7443
Assembly
Fog/Driving light
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
License plate
2825
Back up light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
2825
Rear sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Step/Courtesy light
2825
Trunk/Cargo area
DE3021
Low beam headlamp
HID-D4S
High beam headlamp
9005
Parking light
2825
Front turn signal
992 (7440A)
Rear turn signal
992 (7440A)
Tail light
7443
Stop light
7443
Assembly
Fog/Driving light
9006
License plate
2825
Back up light
921
Front sidemarker
2825
Rear sidemarker
194
Step/Courtesy light
2825
Trunk/Cargo area
DE3021
only if you have the money to keep replacing them... high beam is for the purpose of short blasts of light... while HID needs time to charge up and cool down.. if you run HIDs in the high beam you'll end up with a burnt out HID bulb very quickly.... not to mention possible damage to the ballast... so unless you're cool with spending at minimum of $80 on replacement HID bulbs, i wouldnt recomend you doing so.
Blueshark
ES - 5th Gen (2007-2012)
02-27-18 06:04 AM
VinnRock
IS - 1st Gen (2001-2005)
03-03-09 01:32 PM
