Interior light bulb sizes & replacement
good news!!! the IS white LEDs fit on the ES!!! i just put mine in... and they look great...
bad news.... i just realized the glove box and the center island is lite up by the same red LED... does anyone have any idea on how to access them?
thanks for the part number on the foot leds wewnt to get my first oil change on wed and orderes them installed them just now and now they match my whole interior and hid kit thanks............NOW if i can just figure out a way to swap the puddle lamps and i'll bee all set!!!!!!!!!!
so would you have to get 2 of these parts? Also, could you tell me how you can remove the passenger side led? thank you!
I actually drive an ES330 so one of the other guys would have to answer you. If it's like the ES350, there's a little trim piece under the dash in the passenger foot well that the LED is attached to. With my car I just pull the trim piece down and out, then I have access to the LED assembly.
Does anyone know if the LED in the glove box and center armrest area are white LEDs in the IS and if so, have you swaped them out in your ES to match everything else in white LED?
I need help ASAP!
I just got my shipment in of LEDs from VLeds for the ES350. I've put them all in and they all worked, except the one for the rear passenger dome light does not. I ordered a similar type but it does not seem to work when I put it in. Can anyone who has replaced it with a white LED please let me know which one you used?
Thanks!
Thanks!
I need help ASAP!
Thanks!
Thanks!
smarty666. yes it doesn't work for me too and i bought it from v-leds as well. lol so i guess we are both loyal customers from there. I just got the Platinum 7443 brake light, hopes it is as bright as i expect.
- and Nevernu, im sure he used resistors because if he didn't, he would get hyper blink which happen to my 07 es350.
