ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
To those who change their own oil
Old 02-25-08 | 11:00 PM
myes350's Avatar
myes350
Default To those who change their own oil
To those who change their own oil. Its usually a good idea to change the crush washer on the oil drain plug at each change. To those who do so, does it come with the Toyota/Lexus oil filter or do you buy them seperately. If purchased seperately, as they a generic part or is do you just purchase them from Toyota or Lexus (curious how much they run each)
Thanks
Old 02-25-08 | 11:07 PM
ng123ray's Avatar
ng123ray
i dont think the drain plug gasket comes with the filter.(maybe it does) i havent done an oil change recently so i forgot... but the filter is about $6 ... and it comes with all you gaskets...
Old 02-26-08 | 03:43 AM
BillP's Avatar
BillP
The crush washer does not come with the new filter. Some dealers are good enough to tape one to the filter box a no cost. Just ask when you pick up your filter, the parts guy will probably just give it to you.
Old 02-26-08 | 10:09 AM
dreyfus's Avatar
dreyfus
I've been changing my own oil for 35 years now and have replaced the oil pan plug washer I think twice. I've never had a leak from this point.
So, no, I don't replace this washer and obviously don't think it's needed. However, you can spring for a new one if it makes you feel better. It doesn't come with the oil filter kit.
BTW, always change all the O-rings provided in the filter kit when you change the oil.
Old 02-26-08 | 11:31 AM
SmokeyES35's Avatar
SmokeyES35
Default yeah
both my father and brother are mechanics, so oil change and tune ups and all that is done at home.. and yeah..we always get a washer taped to the oil filter, but usually buy it.. depending on if we know the person at the counter... every 3000 miles.
Old 02-26-08 | 02:58 PM
<VENOM>'s Avatar
<VENOM>
Don't really make it a habit of changing the oil filter washer, it's not a crush washer, it's made of some composite material, like a quarter with a hole drilled through it I guess every 5 changes I put a new 1 on cause I have them
Old 02-26-08 | 04:52 PM
n2cars's Avatar
n2cars
I've always changed my own oil and sort of enjoy it. I work behind a keyboard most days so a concrete floor and oily hands is a welcome retreat every 3k miles. My first oil change on the es350 is about a week away. Are there any lube fittings? My suburban has many, many, grease fittings to lube but my 2000 ES300 has none. What's the story on the ES350. I don't expect to find any, but thought I'd ask.
Old 02-26-08 | 07:46 PM
onepointon's Avatar
onepointon
No lub fittings. They are really taking away all your fun, aren't they?
toyotabike
03-07-17 04:29 AM
neomedic
01-11-12 07:11 PM
lilbluu
06-01-10 04:44 AM
wakaru8
12-23-09 09:07 AM
underway
07-13-09 07:47 PM
