ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Old 12-15-14, 04:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Friend's 2007 Lexus ES350 passenger window fell out.
Old 02-10-16, 08:41 AM
  #91
AkelaNoel
AkelaNoel's Avatar
Originally Posted by craig72
I had this happen to my passenger glass about a year ago. Bought an aftermarket glass on ebay for about $105 and spent about an hour putting it in. My car is an 07, so going to the dealer is out of the question. New glass looks just as good, same original tint color and all. Easy fix. I thought about just buying the driver one and keep it in the attic until that one breaks as a precaution.
Do you mind providing details on which part you purchased and instructions for fixing the problem?
Old 02-15-16, 07:18 AM
  #92
craig72
craig72's Avatar
I bought my replacement glass off of ebay. Shipping was great (well packed, arrived quickly) and it fit perfectly. Window is still working w/o issue after 3 years installed.
As far as directions, I have the Haynes manual for this car which describes in detail how to remove the panel and glass (more direction than I could provide here). Amazon sells the book for about $21 and it is worth it. Good luck!
Old 05-09-16, 06:26 AM
  #93
BGElliott
BGElliott's Avatar
This just happened to me yesterday and I freaked out. Does anyone know if it's a mm easy cheap fix or will it cost me an arm and a leg? I just bought the car about 6 weeks ago and I'm really hoping I don't have to spend tons of money to fix this. :-(
Originally Posted by NTXES350
If more people come forward we may discover a pattern. I had the windows come off track to my 2007 ES350 twice. The driver side window (tinted) got off track within the first year. The window shattered when they attempted to inspect it. It happened to the passenger side about one month ago, still under warranty. If your window makes loud noises when openning and closing, you should take it in. That is the precursor to it fully coming off track.
Old 05-09-16, 06:42 AM
  #94
BGElliott
BGElliott's Avatar
This is EXACTLY what happened to mine yesterday. I thought it was going to literally fall out after it popped about 2-3" up and out of the track. My husband had to gently ease it back in and now the lights on the window switches are flashing and the driver side switch for the passenger front window will not work.
Originally Posted by bmwmpower
On my friend's ES350, the passenger window just came out of the door as it was being rolled up. The top corner near the B-pillar was just sticking out and you could fit your hand through there with the door closed.
I wanted to know if this is a common problem? I looked and looked but just see the transmission flare issues. I like the ES350 and the general direction Lexus is going in terms of design, etc., but that really is dissapointing for a brand new Lexus with less than 5,000 miles on it. The window is being repaired under warranty and re-tinted.
Old 05-10-16, 07:14 PM
  #95
retired
retired's Avatar
Common problem on the 07 and 08 es350. This is a design defect.. Two plastic tabs are built into the glass. The plastic will crack and the window will make a popping sound prior to coming off track. This happened to me in 2011 and the dealer wanted $660 to replace.. Went to an auto glass shop and had it replaced with an aftermarket glass for $220 (has a lifetime warranty). The pinch protector has to be reset manually, which is easy. Directions on how to reset the pinch protector are available on the internet.. Have to take off the door panel to unplug and re plug the window motor. Hope this helps
Old 05-11-16, 11:29 AM
  #96
BGElliott
BGElliott's Avatar
Hope it won't keep happening if I get it fixed. Such a bummer. I only bought this car about 1 month ago and it's really frustrating to have something so expensive go bad so soon with it.
Old 05-30-16, 08:36 AM
  #97
Chobit
Chobit's Avatar
The same thing happened to me and I opened the panel to find the plastic tab broken. I used super glue to glue it all together and it worked for about a year. One day when it was -40°C I tried to open the door and the tab broke again. I'll probably re-open it up and superglue it again.Has anyone else did something similar? Did you find any other way of reinforcing the strength of the plastic? I read somewhere that someone got rid of the plastic and replaced it with an aluminum tab instead. I don't recall where I read that though.I've also measured all the dimensions of the tab the last time I opened up the panel. I should be able to 3D print it if I chose to but I have doubts the strength of printed material is as strong as the original plastic. It's probably better to have it machined in aluminum...
Old 05-30-16, 08:47 AM
  #98
nevernu
nevernu's Avatar
https://www.clublexus.com/forums/es-...b-problem.html
fixed link
see post 7 in the above thread, he replaced the plastic tab w metal
Old 05-30-16, 08:50 AM
  #99
Chobit
Chobit's Avatar
Originally Posted by nevernu
https://www.clublexus.com/forums/es-5...b-problem.html
Thanks! By the way the link you posted didn't work. Here it is for anyone interested:https://www.clublexus.com/forums/es-...-problem.htmlI PM'd him for some pictures
Old 06-12-16, 06:53 PM
  #100
BGElliott
BGElliott's Avatar
Default Lexus rocks!!!
I cannot believe it but Lexus covered the cost of parts for me on this. The quote was $850 (discounted to $580 by my dealer) and I ended up only paying labor of $125. I am so pleased with Lexus it not even funny. My car is 10 years old and has 108,000 miles so I was not expecting any help with this. So happy!
Old 08-13-16, 12:55 PM
  #101
Blue Moose Engineering
Former Sponsor
Blue Moose Engineering's Avatar
Sorry to bump such an old thread...not trying to spam or anything.
This is probably the most-viewed thread on this problem on the internet. I'm a little late to the party, but this issue still affects a lot of cars and most dealers aren't helping much with the costs anymore.
I've designed and manufactured an aluminum replacement for this. I sell a kit that comes with everything you need to do the repair, including a tube of application-specific 3M adhesive and detailed instructions. Check out my website for more information. If you're a Club Lexus member, PM me for a discount.
Old 08-16-16, 04:08 PM
  #102
Former Sponsor
Originally Posted by lunker10
You folks need an education on how those windows are designed. The reliable way to connect the regulator to the window is to waterjet 2 holes into the glass and mechanically connect the window to the regulator with bolts or rivets. This is how REPUTABLE auto designers operate. This basically lasts forever. Lexus and some low reliability US manufacturers figured out they can save $4.00 per window by gluing plastic tabs onto the glass and mounting the regulators thru these tabs. They also use less glass. The etching compound used to prep the glass to the tab can react with the plastic tab causing the plastic to get brittle and break over time. And/or the plastic tab is formulated with insufficient plasticizer (expensive part of the plastic formulation) which also causes the plastic to get brittle and break. You would think that when you buy a premium car you would get the best design but we got the worst design from Lexus. They are not about to fix all these defective vehicles at $2000 per copy. Our only recourse is to file a complaint at www-odi.nhtsa.dot.gov. The government forced Toyota to do a recall in 2008 for a similar problem on bad window connections on Corollas and Matrix. See NHTSA Campaign 08V162000. Signed Materials Engineer.
For some reason page 5 of this thread, and this post in particular, comes up first in nearly every organic search I do for this problem, so I'll just point out again like I did in my how-to thread, that as the Quality Manager at a glass company, I can tell you that putting holes in a moving piece of glass is generally something designers try to avoid. A hole in glass is essentially a planned/controlled defect, and a hole that close to the edge of a piece of glass...especially attached to a moving assembly...is a break just waiting to happen. Also water-jetting glass is not the preferred operation for making holes. It causes too much chipping and flaking and can even break the glass.
I could be thinking of something else, but I believe that mid- to late-90's GMs liked to do this and suffered from a fair amount of failures. For some reason I'm picturing that awful Z24 Cavalier turd.
So for anyone reading this thread all these years later...don't leave here thinking that you should waterjet holes in glass. There's generally nothing wrong with plastic clips and definitely nothing wrong with adhering clips of any material to glass. This is good engineering and good accounting as well
Old 05-17-17, 03:35 PM
  #103
aprilgirl
aprilgirl's Avatar
The passenger window on my 2008 ES 350 had been a problem for months so I finally took it to my trusty Japanese Import specialist. He had to pull off the door panel to check it out -- at a cost of $60. He found the problem to be a broken window clip. Unfortunately, the clips aren't sold separately and come as part of the window glass assembly. The dealer wanted $519.00 for the glass assembly. However, the technician said he could get a used one for half the price. Turned out the technician's parts source sent over a brand new Lexus front passenger window glass because that particular glass was overstocked! The technician waived the $60 diagnostic fee (I'm a regular customer) and charged $95 to replace the glass. I remember reading a post from one of the forum members about selling the clips. Since this is a fairly common problem you'd think Lexus would take some action to address it. Guess that's just wishful thinking!
nbrown8883 (04-23-18)
Old 04-23-18, 12:01 PM
  #104
nbrown8883
nbrown8883's Avatar
Hello Aprilgirl. Would you be willing to share your tech's info? I am also in Georgia and my passenger side window collapsed somewhat this morning. It has been raining like crazy and I would like to get this fixed ASAP!!! Thanks.
Old 04-23-18, 04:31 PM
  #105
nevernu
nevernu's Avatar
https://www.clublexus.com/forums/es-...l#post10180323
detailed solution above and his web site is
https://bluemooseengineering.com/
Ive replaced front clip on both my windows and highly recommend.
(for some reason the info is suddenly hard to find on CL)
Quick Reply: Friend's 2007 Lexus ES350 passenger window fell out.
