Check VSC message
I started the car Friday after it sat about 30 mins. It went through its system check, then the "check VSC" message appeared along with the red triangle light. It stayed on about 5 seconds and went out. It has not appeared since.
I realize there are probably no codes stored and I also realize computers can have a glitch once in a while. However, just wanted to know if this has happened to any of you.
