ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Rear sway bar available for ES350?
Old 05-22-19, 03:23 AM
ESh
ESh's Avatar
The sway bars from a Camry are 1 mm thinner.
Old 05-22-19, 04:55 AM
ilkinandr
ilkinandr's Avatar
Rear Sway
48812-06080
2012 Lexus ES350 Base 3.5L V6 - Gas
2011 Lexus ES350 Base 3.5L V6 - Gas
2010 Lexus ES350 Base 3.5L V6 - Gas
2009 Lexus ES350 Base 3.5L V6 - Gas
2008 Lexus ES350 Base 3.5L V6 - Gas
2007 Lexus ES350 Base 3.5L V6 - Gas
48812-06080
Toyota Avalon 2012 Base, Limited 3.5L V6 - Gas
Toyota Avalon 2011 Base, Limited, XLS 3.5L V6 - Gas
Toyota Avalon 2010 Limited, XL, XLS 3.5L V6 - Gas
Toyota Avalon 2009 Limited, XL, XLS 3.5L V6 - Gas
Toyota Avalon 2008 Limited, Touring, XL, XLS 3.5L V6 - Gas
Toyota Avalon 2007 Limited, Touring, XL, XLS 3.5L V6 - Gas
Toyota Avalon 2006 Limited, Touring, XL, XLS 3.5L V6 - Gas
Toyota Camry 2011 Base, LE, XLE 2.5L L4 - Gas, 3.5L V6 - Gas
Toyota Camry 2010 Base, LE, XLE 2.5L L4 - Gas, 3.5L V6 - Gas
Toyota Camry 2009 Base, LE, XLE 2.4L L4 - Gas, 3.5L V6 - Gas
Toyota Camry 2008 CE, LE, XLE 2.4L L4 - Gas, 3.5L V6 - Gas
Toyota Camry 2007 CE, LE, XLE 2.4L L4 - Gas, 3.5L V6 - Gas
Tmann77 (05-22-19)
Old 05-22-19, 04:56 AM
Tmann77
Tmann77's Avatar
Default Es 350/Camry sway bar
As long as the geometry is the same that means I can by the thicker upgraded ones for the Camry and install them on my Lexes ES350
Old 05-22-19, 04:59 AM
Tmann77
Tmann77's Avatar
Default Sway bar
Originally Posted by ilkinandr
Rear Sway
48812-06080
48812-06080
Thanks for the information!!!
Old 05-22-19, 05:17 AM
Tmann77
Tmann77's Avatar
Do you know if the front sway bars are interchangeable?
Old 05-22-19, 05:22 AM
ilkinandr
ilkinandr's Avatar
Front Stabilizer Bar
48811-33190
2018 Lexus ES300h Base 2.5L L4 - Electric/Gas
2017 Lexus ES300h Base 2.5L L4 - Electric/Gas
2016 Lexus ES300h Base 2.5L L4 - Electric/Gas
2015 Lexus ES300h Base 2.5L L4 - Electric/Gas
2014 Lexus ES300h Base 2.5L L4 - Electric/Gas
2013 Lexus ES300h Base 2.5L L4 - Electric/Gas
2018 Lexus ES350 Base 3.5L V6 - Gas
2017 Lexus ES350 Base 3.5L V6 - Gas
2016 Lexus ES350 Base 3.5L V6 - Gas
2015 Lexus ES350 Base 3.5L V6 - Gas
2014 Lexus ES350 Base 3.5L V6 - Gas
2013 Lexus ES350 Base 3.5L V6 - Gas
48811-33190
Toyota Camry 2014-2015 LE, N, SE, XL
from what i could find.
Old 05-22-19, 06:24 AM
ESh
ESh's Avatar
Yes, but you have to buy the bushings and the bush holders So it is better to go with the ES 350 sways.
Old 05-22-19, 10:53 AM
igzy
igzy's Avatar
Camry drivers have used UR RSBs. Apparently they come in two options as 19mm and 23mm diameter:
https://www.toyotanation.com/forum/1...-sway-bar.html
http://ultraracing.my/ecatalog/index...5-v6-2wd-2011/
An in-between solution that will improve the stability would be to just change the bushings to stiffer poly...
Old 05-01-20, 05:00 AM
PJZX14R
PJZX14R's Avatar
Picking this up again. Has anyone confirmed that the Ultra Racing rear bar fits the ES350?
Old 05-01-20, 06:05 AM
Clutchless
Clutchless's Avatar
Received 1,161 Likes on 990 Posts
I looked at the Ultra Racing site and none of those products are anti-sway bars. They are all extra bars to stiffen the rear end.
I wonder if an RX350 rear bar would fit as I think it is 23mm. A photo or parts listing drawing comparison should show if they are the same, shape. Then you would need the brackets and rubber bushings. The OEM price is not bad and a junkyard one even less, but getting it out of a junker may require a hacksaw or battery powered grinder.
Also, sway bar links often rust so much that you have to cut them off, so be prepared to do that. I found that the allen screw hole in the center of the end link strips when trying to remove a rusted end link. A grinding wheel helps, or destroying the end link ball joint from the other side and hammering it apart.
There are some Bay seller of polyurethane sway bar bushings for many Lexus and Toyota products. I got a pair for my RX350 rear bar for about $26 and they come with the grease you need for poly bushings. Try searching.
Old 05-01-20, 06:25 AM
PJZX14R
PJZX14R's Avatar
https://ultraracing-usa.com/toyota-c...nti-sway-19mm/
Thanks for the guidance. Ultra has a 19MM rear bar for the Camry. See link. They just won't guarantee a fit and products can't be returned.
KYBs will be installed this weekend. This car sat in my 85 year old father's garage since new - no snow/no salt/no commuting so no rust.
Old 05-01-20, 06:32 AM
PJZX14R
PJZX14R's Avatar
Car is 2009 ES350 Pebble Beach. <59K miles
sorry, new and haven't figured out how to add a signature yet
Old 05-23-20, 02:47 PM
PJZX14R
PJZX14R's Avatar
BushyRambl (05-24-20)
Old 05-23-20, 02:48 PM
PJZX14R
PJZX14R's Avatar
If you were curious, the Ultra 19 mm Sway Bar for the Camry fits perfect. See pics.
Old 05-24-20, 05:44 AM
delerium75
delerium75's Avatar
How's it compare to stock? Have you driven it yet?
Quick Reply: Rear sway bar available for ES350?
