Oil Maintenance Needed Display
Cannot get rid of / find in the manual on how to reset / get rid of the display telling me I need an oil change. Just asking for some help on this. Thanks in advance / did a search in the forum and could not find.
I'm looking at my wife's owner's manual now. She has an '08, and it has the reset instructions on P. 308 in the Do-it-yourself maintenance section. It Reads:
1. Turn the "ENGINE START STOP" switch OFF with the trip meter.
2. While pressing the trip meter reset button, set the "ENGINE START STOP" switch to the IGNITION ON mode. Continue to press and hold the button until the trip meter displays 000000.
Lou
Lou
The user manual instruction is not detail enough. To reset oil maintenance light, follow these steps:
1. Set trip to A by pushing in the stem under the speedometer.
2. Shut off ignition.
3. Press in stem and hold as you push start button twice (do not put foot on brake).
4. After seeing a row of 0000000 from odometer, release stem.
5. Start ignition, it will go through check and light will be out.
StylinGS300
07-05-09 03:16 PM
