The plastic trim running along both sides of roof popping up slightly at the ends
On the ES350, has anyone had issues with the plastic trim running along both sides of the roof popping up slightly at the ends?
I had the same thing, the dealer glued it back into place, they were going to order new peices but it was going to be 2 weeks and there is no way i was traveling there again in two weeks...
they re-glued / double sided taped it down, but it is still sticking up again a bit.
https://www.clublexus.com/forums/es3...rim-piece.html
If they remove the trim, they MUST use new clips!!
See this file.. It might help you out:
http://www.filesend.net/download.php...f6155bc09a2f23
