Personal Best - 34 mpg!
FYI as I mentioned I usually fill the tank up so that you see fuel at the top of the filler neck. So I have been watching the fuel gage and the neddle did not move from the far right (slightly above the full mark) until I drove 75 miles. Also being this was local city miles I was only getting 22-23 MPG. After the 75 miles the neddle moved to the full mark. So if you want to get an accurate check you would need to fill it to the top and then drive 100 or so miles and refill it to the top and do the math. That will give you an accurate measure and will allow you to check it against your info panel reading.
And! Always filling it the same way should render comparable results.
its normal for the mpg's to go down with the bad weather. your avg speed falls dramatically hence much lower mpg's. its not a hybrid...
I was getting an average of about 28mpg in my daily commute to work: some light city traffic plus mostly rural 45 mph roads with an occasional stop sign.
Then we had a pretty long snowstorm and all of a sudden my last tank is less than 22mpg!![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I am not driving any different than before, but the heat and heated seats are on most of the time. I guess VSC and TCS engaging frequently because of slippery stops/starts and corners send a lot of engine power into the brakes. Indeed YMMV...![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
