Weather Warning Message & Seat Movement?
Thought I'd take the lazy way out and ask you guys before I look through the Owner's Manual.
First: How do I turn the Weather Warning message off? Each day, when I first use my car (2010 ES), the warning message is broadcast even though there is great weather for hundreds of miles around. Will the message stop after the 3 month XM Weather trial?
Second: My steering wheel tilts upward when turning off the engine and back into position when starting, but the seat does not move. I am short, so the seat is pretty far forward. On other cars I have owned, the seat moved back when the steering wheel moved up to make it easier to get out of the car. Is there a setting that controls the auto movement of the seat that I can change through the Nav screen, or is this feature not available on the ES?
Thanks for your help.
I don't know about the weather warning because I don't get it - we don't have bad weather in Arizona.
Only the steering wheel moves out of the way in the ES but you can set one of your seat memory positions to where you want the seat to be on entry then when you open the drivers door you have a brief time - maybe 30 seconds - to touch the pargrammed seat memory button and it will move the seat back before you enter the car. If you need the seat further up to drive you could then use the other memory button for that position. You can even link the entry position to your smartkey remote so that when you approach the locked car the seat will position itself before you enter.
Dave Mac
Dave Mac
Dave Mac
Dave Mac
I went through the menus on the Nav screen and under "Voice", there is an on/off setting for the Weather Warning message. I switched it to off, so that should solve my problem.
