ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Transmission Fluid Change
Old 01-17-10, 09:39 AM
bhaubold
bhaubold's Avatar
Default Transmission Fluid Change
Does the ES350 have a trans filter that would be changed with the fluid? Is there a mileage interval for this?
Thanks,
Bob
09 ES350
Old 01-17-10, 01:13 PM
Dave Mac
Dave Mac's Avatar
I believe the ES350 has a "sealed" transmission - no fluid change and no filter except for a transmission rebuild.
Dave Mac
Old 04-08-11, 09:09 AM
rx300mm
rx300mm's Avatar
Apparently, the manual says 100k for ATF changes but see below link, this guy changed it at 50,000 miles and gives detailed steps.
http://us.lexusownersclub.com/forums...howtopic=59422
Old 04-09-11, 09:19 AM
dreyfus
dreyfus's Avatar
Dave Mac is correct. My manual says the sealed unit doesn't require transmission fluid changes, ever.
I still have my doubts about any fluid being "lifetime".
Old 04-12-11, 08:27 PM
CDN_Drew
CDN_Drew's Avatar
The service manual for the Canadian ES350 says to replace at 60k miles or 96k km. My car is nearing that mark and I'm not sure what to do...replace, replace+flush...?
Old 04-13-11, 05:07 PM
safford197
safford197's Avatar
Agreed, IMO "Lifetime" should be assumed to be equal to the period of time the MFG is willing to provide a warranty, not equal to the rest of your life...
Old 04-13-11, 08:07 PM
CDN_Drew
CDN_Drew's Avatar
It can't hurt to change it through right? The cost at my mechanic to replace is $70 and to replace+flush is $140.
Old 04-13-11, 11:53 PM
gemigniani
gemigniani's Avatar
Just checking the fluid level - let alone changing it - on a 2007 on up ES is complicated. Independent shops don't have the tools or know how to do it - especially for a mere $70. These cars are not like your fathers Toyotas.
The fluid DOES need changing - if you want the transmission to last far longer than the 70,000 mile powertrain warranty.
Old 04-15-11, 09:52 AM
rx300mm
rx300mm's Avatar
Sounds like a good deal, if you consider it takes 12 quarts ATF ( $6.60/qt by the case at a Toyota dealer).
It does take a lot of time to completely flush ..
Old 04-15-11, 08:33 PM
safford197
safford197's Avatar
Anyone paid for this at their dealer? I wonder how much the service is, at Lexus or at Toyota dealership?
Old 04-17-11, 08:51 PM
CDN_Drew
CDN_Drew's Avatar
My mechanic is a Lexus pro tech who started his own shop with another Toyota/Lexus tech. Truth be told, I haven't the foggiest how they do it so cheap, but they seem to be conscientious...this is a major service though.
Old 12-12-12, 02:01 PM
bwong
bwong's Avatar
Below is what dealer did regarding how to change transmission fluid (2007 ES350):
"""The transmission fluid to be replaced on your car has a drain plug to drain the fluid and a side entry to re-fill the transmission fluid. We place the car on the hoist and drain the fluid. We then install transmission fluid through the side entry hole, start the car and monitor the operating temperature. When this transmission fluid temperature reaches the required spec, we add fluid as required until the fluid starts to drain off from the fill entry point. This replacement service takes approximately 2 hrs as the car transmission fluid has to reach the specified temperature before closing off the system. The transmission does have a drain plug, to remove old fluids. For your information
Thanks
Stephen De Castro
Assistant Service Manager
Lexus.OnThePark.Logo_sm
P: 416-391-8822
F: 416-391-1612
E: decastro@lexusonthepark.ca
Old 12-12-12, 06:50 PM
John U
John U's Avatar
It appears that by measuring how much oil drains out and adding the same amount of fluid back in should be scientific enough?
Old 01-13-13, 11:46 AM
chuyrobles
chuyrobles's Avatar
Assuming it had the right amount to begin with. Factor in leaks and don't assume the factory filled it up properly.
Old 05-18-13, 01:05 PM
ThumperPup
ThumperPup's Avatar
my factory Drivetrain warranty is expiring in 10 days
and the Build date of the car was 5/20/2007 so i figured with it having 54k and being 6 years old in 2 days it is time to do some service
today i had the Coolant system flushed out and replaced with proper antifreeze for the Toyota
had the break lines flushed out break peddle seems better then it did before
asked the shop if they could do a power steering system fluid flush they told me they don't deal with that service so ill have the dealer do that i guess
but i wanted to get a transmiions fluid exchange done
but they don't yous toytota transmisons fluid i know in the owners manual it says to use toyota transmision fluid and it gives a reason why not to use another kind of fluid
but wondering if its really true about how it can shift differently is it really required to use toyota lexus fluid
or will i be fine to have the shop echange the fluid with there valvoline or what ever other brand fluid they use ?
Quick Reply: Transmission Fluid Change
