Gas Pedal Fix for 2007 ES350
#50
Thanks for posting the pics. I must say that I'm not feeling the cut pedal and how they shaved back the carpet, doesn't look too good IMO. I know I'm going to have to bring in my ES for the 5K service, but from what I've been reading, there is no way around this 'fix', there is no waiver, the ECU reprogramming I'm on onboard with, but the pedal/carpet shave I'm not..
#51
Trimming the pedal is like cutting your finger nail (but upside down). Some mechanics seem to be cutting deeper than others. Mine was not cut as deep as the pics. Also, because I have black carpet, I cannot tell if anything was done to it.
#52
#53
I agree. I've had the job done on two cars. By the time I got home from the dealership it was forgotten.
#54
ALL,
Here is a "what if" to see if anyone knows! With regard to the sudden acceleration ECU reprogramming fix on my ES350 does anyone know how or which device sends the signal to the ECU so the brakes will override the throttle?
If Toyota/Lexus is depending on the brake light switch to signal the ECU what happens if the brake light switch fails or the brake lightbulb fails? BTW, brake light switch's are NOT the highest quality failsafe type switches.
If they are depending the brake light switch, the ECU reprogramming fix may NOT be a dependable true failsafe fix. Anyone know???
#56
Toyota isn't so stupid to use the brake light switch or bulb to activate an important safety system. They would use sensors that are in the brake system itself probably the master cylinder that sense brake line pressure as used on the anit-lock system. The main computor will probably be the control that does the shut off. No system is perfect, but this one will be very well thought out.
#57
CJS57,
Thanks, good thought. The anti-lock brake line pressure sensor would be a MUCH better choice than the brake light switch.
As for Toyota being smarter, I wonder because the public is hearing so many denials just like other car companies have done in the past.
But as a friend of mine says, "not my problem," that is, except for our own personal 2007 ES350 and our safety in that specific car.
Thanks again for the reassuring thought.
#58
I wanted to assure you that the repairs are very professional. In fact my repair appears to be a new pedal and not something that was carved. In fact there is a part number line on the work order for the accelerator and the pad along with a labor charge line.
#59
FWIW, if after your gas pedal was re-shaped and you’re not happy with the result you can get the new gas pedal installed for free under the recall campaign. Please read below:
http://pressroom.toyota.com/pr/tms/t...ng-155713.aspx
Toyota Statement on Replacing Accelerator Pedals (March 23, 2010)
Some news accounts have misinterpreted a letter sent by Toyota to its dealers regarding an improved parts ordering process for accelerator pedals to suggest that this represents a change in Toyota’s policies regarding the remedies for its recent recalls.
Toyota is confident that the remedies it has announced to address sticking accelerator pedals and floor mat entrapment represent a comprehensive solution to these issues. However, if a customer is not satisfied with the modification to his or her repaired accelerator pedal, dealers will replace it at no charge.
This policy was included in Toyota’s Defect Information Reports (DIR) filed with NHTSA in November regarding floor mat entrapment and in February regarding sticking accelerator pedals and is also contained in the official owners letters for those recalls.
#60
took my es350 2007 in for the HOSE and mat/pedal service.. they did do a wash and tank fill..
with the re programming, the car is sounding smoother! just love it. . I used to get a bit of kickback noise with the pedal earlier, and dont know. hence I consider this an improvement.. The mats . look the same to me. ie. i dont think they replaced my MATS
and BTW, i saw the CHARGES on the bill which we signed. .no cost to us but 990$ APPROX WAS THE CHARGE the DEALER invoiced LEXUS.... LOL
