2 smalls bars in the trunk under the sub ??
What does thoses bars used for ? I notice that it rattles alot when the bass hit. Seems like they are to thin to be strutbars. The fact that they are joined in the middle under the rear deck platform, it vibrate to any bass sound. Can it be removed because i tried to wrap foam them, that doesn't work.
thank you.
thank you.
unfortunately, i shoke it a little bit, i may have pull a little bit also from the chassis. Is there something inside it ? and how will i know i cause come damage.
thank you.
thank you.
The 2 bars located in the trunk near the speakers are the torsion springs that hold the trunk open. These are solid steel bars and are held in place by a few clamps. If the bars come out of the clamps they will rattle. They should not be loose. There are no brake lines or fuel lines inside the trunk.
I am also experiencing the same rattle noise from these two torsion rods, when the trunk is open these two rods seems to be tight and free from rattle, the problem is when the trunk is closed then they became loose and make rattles when the bass is up, anyone got a fix of it ? I've tried to stick some styrofoam in between and while seems to work but from time to time I have to re-position them and clean up the trunk from all the falling loose pieces, wonder if anyone has a better fix......
Pete
bighitbike
01-16-08 06:27 PM
Drrawdog1
08-14-06 12:50 PM
jtgs400
01-31-06 11:04 AM
engin_ear
05-12-02 11:51 AM
