a thing about keyless entry which confuses me
suppose the car is stopped..
can u turn the engine off. without turning off everything. it was simple to do with key ignition.
here if we put it is park and press the button, everythnig shuts off.
Engine has to be shut down 1st. After that if you hit the button, w/o stepping on the brake, you will go into ACC mode (radio, etc.). Repeating this procedure will get you to the ON mode where you can control windows.
YOU GUYS ARE THE BEST..!. I knew there wud be a trick
ok. ANOTHER qs. IF I do the above.. and put in N. and stop the engine.. then move it to park. and ELECTRONICS are on.. then if I walk away from the car... what will happen
will it auto shut off. after a certain period of TIME. is doing this a good/bad idea.?
Are you sure? One time after pulling in the driveway I left the car running and got out to let my wife take it up the street to the 7-11 for something. A moment later she pulls up and sticks her hand out the window for the fob.
Thank goodness she noticed the warnings on the dash.
^^^^I don't know what will happen to the car if it's ACC mode without the fob. I do know, if the engine is running, and someone drives off without the fob, it will keep on running until it is turned off. That is, it will run, and not stop, unless it is turned off or runs out of fuel. When that happens, of course, it will not restart.
Lou
Lou
So our car has an automatic engineshut off, but not the electrical shut off.
elbarto
11-22-22 02:13 PM
netcbc
RX - 3rd Gen (2010-2015)
08-27-15 12:57 PM
cheappc
05-20-08 10:05 AM
