Trunk Lining Material
Does anyone know where I can find the material that the trunk lining is made of, or a material that is nearly exact in color and texture.
I tried a "charcoal" polyester felt from our local fabric store, but it was much lighter than I though (bought the material after dark!). My wife suggested that I dye it darker to match, however, through a bit of research I found out that polyester is very difficult to dye, and is a task that really should not be attempted by an amateur.
My intentions are to use this material to cover my custom subwoofer enclosure and I want it to look as if it were an OEM option. I am not a fan of the after-market, flashy look.
Once the enclosure is finished, I will post pictures in a separate thread.
Go to your local stereo shop...they build speakers boxes and line with material that matches the trunk. Also you can go to your fabric stores they carry headliner material and trunk material as well. Hancocks is a fabric store near where I live that I get all that material...and usually 40-50% off.
I went to the fabric store online that you referenced, and purchased some material thats looks closer in color that what I bought (Item# 2660827). Hopefully it works out.
Thanks for the info.
