How to check if recall work has been done?
I read on one of the threads where you can enter your VIN and confirm if the recall work has been completed on that vehicle. Im buying a used es350 and i want to see if the work has been completed. Does lexus have a website that allows you to enter the VIN and report which recall work has been completed? If so please pass along the link.
Thanks
Thanks
Thanks
Thanks
Thanks
Thanks
https://secure.drivers.lexus.com/lexusdrivers/home
Register, Name, VIN, and etc. Once in, go to Service History. You'll see what's been done to your car and if there is any Service Campaigns outstanding.
Lou
Thanks
Thanks
Go Here:
Lou
Lou
Also looked up the 2007 that I traded in, and all of the work was listed (I had the recall and service campaign done while I still owned it) as well as things that were done before putting it on the lot as a CPO.
Go Here:
Lou
Lou
"There is currently no service history information available for your 2007 LEXUS ES350."
Could this be because the site had defaults for the U.S. (States instead of Provinces etc.)?
I'm confused about this. I brought my Lexus in to my dealer at each recommended service time.
Toffy,
Go here to see the Gas Pedal fix.
https://www.clublexus.com/forums/5243124-post1.html
And then run this test to see if you ECU was reprogrammed. This, by far, is the most important fix.
https://www.clublexus.com/forums/5257673-post25.html
dotbowels
RX - 3rd Gen (2010-2015)
12-26-12 04:49 AM
