At what mileage to replace Factory Tires & Breaks?
Current Mileage on 2007 ES350: 29000 miles
Thanks in advance.
Thanks in advance.
There isn't a set mileage for tires and brakes. A lot of it depends on driving style, road condtions etc.
If they are the original tires and brakes, at 29k miles, it might not hurt to have them checked for wear.
You should be checking them on a regular basis (at each oil change when you rotate the tires is good time to check). Waiting until 29k miles to even check is a tad bit late. The tires may be down to the cords at this point or they may be good to go another 5k miles.
My rear brakes were replaced at 20,000 miles at n/c under Lexus direction (not a recall). The front brakes passed state inspection at 33,000 miles. Tires are another story. On 3rd set at 36,000 miles, original OEM Michelins did not last.
yes had very good luck with these ( Primacy ) tires on former es330 - 04 veh just sold recently. Will be putting Primacy on current 2010 veh when time comes to switch OEM Michelins....will say these OEM drive and feel very solid/comfortable just know the mileage output will be in 20--30k range .
Have the cheap Kumho Solus tires on mine for about 18,000 miles now. Still wearing well, plenty of tread left. I think they were $88 per tire 1-1/2 years ago from Tire Rack.
Tires have a shelf life of 6 years. After the tire is 6 years old, beware.
see the articles below:
http://searchwarp.com/swa59705.htm
http://www.aa1car.com/library/tire_expire.htm
Brakes, have the pads measured at maintenance intervals.
I bought my car at 34k and got all new tires ive got 91k on her now the tires are in fair condition. My rear pads went at 54k and i don't know if they did the fronts before it bought it but I havent done them. My old celica the rear pads went at 50k something and the fronts lasted till about 87k.
