sound system help
Just brought a 2010 lexus es 350 -- the radio needs some help -- I did not spend the money for the Mark Lev. upgrade thinking that I could put in aftermarket stuff that is usually better than dealer items.
Just realized, however, that you can't change out the stock cd player unless you have a kit --
Has anyone upgraded there sound system? what did you do
Options I think are -- 1) if anyone knows someone that makes an aftermarket dash kit
or 2) intall a audiocontrol lc6 (provided I can find the outputs after the stock amp) and then connect this to a aftermarket amp and change the speakers.
does anyone know if this will sound anygood -- does the audiocontrol lc6 do a good job?? or is it just a fancy high low converter
please help
andy
please help
andy
You can try this guy...not sure how it looks though.
You can use a double din dvd / navi player
https://www.clublexus.com/forums/clu...ml#post5013978
BRIANxJDM
03-06-09 11:12 PM
pr0vakativ
04-12-06 05:57 AM
