2007 ES350 Headlight problem
Hi All,
I have a 2007 ES350 and the driver side headlight went off after 5 min of driving. But, it will come back on when you re-start the engine. Any idea of what the problem maybe? Bulb or Sensor? I would very appreciate for any suggestion. BTW. What's cost to fix above problem might be?
Thanks
Eric
Thanks
Eric
80% chance it is the ballast. 20% chance it is the bulb. You need to test both to determine which one is the problem. Remember that xenon (HID) bulbs MUST be replaced in pairs. You cannot just replace one bulb at a time, in case this is the issue.
Jerseyken (03-05-24)
Hi All,
Thanks
Eric
Thanks
Eric
Looks like nobody knows how much the dealers charge for changing light bulb.
I am thinking I should have bought a Hyndai and never worry about being "entertained" by dealers.
Hyundai used to be buutt of jokes 10-15 years ago. Not anymore.
Xenon bulbs age at different rates which cause the bulbs to change color temperature. I can't tell you how many idiots I see driving around in cars where one bulb is purple (8,000k the old one about to die) and the other is white-blue (4300k the new one). Change them both at the same time to avoid this.
Since the bulb works intermittently, the problem is not with the bulb. A bulb either works or doesn't work. If a bulb fails it ceases to work, period. Miniz is correct that there will be a color shift as a bulb's lumen depreciation takes effect. But this problem is not the bulb. It's likely a ballast or connection problem. This should be covered by your warranty.
Same problem!
Hi All,
Thanks
Eric
Thanks
Eric
Should I contact a Lexus dealer?
I later found out to be a bad bulb, not a bad ballast. Replaced the bulb, and all is good.
It's most likely the bulb. Mine did the same thing.. while driving if I flipped the lights off and back on, it would come back on for a little bit. Service advisor at the dealership confirmed when the bulb is going bad this is typical.
This is covered under the standard warranty (may not be under extended though). If you're covered let the dealer fix it.. if it's your dime try a replacement bulb first.
It's your bulb. This is how the HID bulbs fail. When it goes out you can usually turn off your lights and then turn them back on and the light will come on again, at least for awhile.
It's easy to replace yourself.
1. Remove the plastic HID socket cover by turning it counter-clockwise.
2. Remove the silver metal socket fitting attached to the braided cable by turning counter-clockwise about 45 degrees and pulling towards you.
3. There's a U-shaped set spring retainer that has kind of curled circle ends. This holds the bulb assembly in place by locking into notches on either side at roughly 11:00 & 1:00 on the housing. Pinch those two curled ends towards each other and pull them out and down to clear the notches and swing the retainer downward. This will release the bulb in the very center of the unit.
4. Pull the bulb out by it's base. It's about 3" long and comes straight out. Don't touch the glass if you intend to reuse the bulb.
5. The Toyota HID bulb is part # 90981-20024 (for my 2007 ES350).
6. Holding the new bulb by the base and without touching the glass, push the bulb back into the hole. There are notches & tabs in the base and mount that must match. Just rotate the bulb until it catches.
7. Reset the retaining spring by swinging it up and pushing it in while pinching the curled ends a bit. Release the ends when they lock into the metal notches on the housing. Make sure the retainer is secure before proceeding.
8. Reattach the metal socket fitting by pushing in at and turning clockwise 45 degrees from roughly a 10:00 to a 12:00 position.
9. Reattach the plastic cover by turning it clockwise.
That's all there is to it.
