Maintenance Miles Breakdown
Hi All,
Does anyone have the Maintenance Miles breakdown on when to bring your car for service? (Example: 5k,15k,30,45k,etc,etc)
Also a chart of what services needs to be done for each miles break.
(Check transmission fluids for example)
Thanks in advance.
Thanks in advance.
I don't have one but I can tell you that you don't ever have to worry about the transmission fluid. Toyota and Lexus us Toyota WS fluid which should last for the life of the car. However, I still would change it every 100,000 miles.
You should also have the vehicle schedule maintenance booklet in your car. I would just oil change every 5,000 miles using oem filter and not worry about anything till 100,000 miles. At 100k I would do the usual tune up : belts, spark plugs/wires, filters.
Check your brake pads every so often (15k) for premature brake wear. While your at it look at your struts for leaks. Bad suspension maybe the cause of uneven brake wear.
Pretty much standard maintenance. I don't believe this car needs anything special. If I'm not mistaken shares platform with camry?
YankinDeez
RX - 3rd Gen (2010-2015)
09-18-17 11:34 AM
bmore430
01-02-17 08:16 AM
