upgrade to MARK LEVINSON SOUND SYSTEM
I have a 2007 ES350 w/out MARK LEVINSON SOUND SYSTEM.
I can change the system speakers and amplifier for the system MARK LEVINSON.
the cable from the amplifier is the same for use amplifier MARK LEVINSON?
let me know,
thanks
let me know,
thanks
I have the mark levinson UL and i would not suggest that leap, even thought it is ok for a premium system. I notice on my old car i have a good set of component and sub with 2 amplifiers and it sound as good, if not better than the mark levinson.
Frankly, you can get away with less for a better sound system.
To return to your question: you want to install the mark levinson amplifier in ?
You'll also have to install the ML head unit as well -- the ML amp really isn't a stand-alone component. As already suggested, if you're looking to upgrade your sound system, there are better options than going for the overrated ML system. I have the ML in my 2009, and while I've developed a workaround to coax much better sound out of it, and got a $1600 refund from Lexus corporate for it, if I was going to consider a sound upgrade for my ES, it would be a third-party solution!
The $ you would spend to duplicate the ML system would most likely buy a non oem set up that would blow the doors off the ML system. Just search for a real high end installer in your FL area.
To my understanding the Mark Levinson head unit can play DVDs is that true? I know it’s old school but I personally feel like that is reason enough to have the ML. Can the non ML units play DVDs? It’s rare to find a used ES350 in my area fully loaded. I have found a black/black 2008 model fully loaded except the ML unit but if I go for it wondering if a ML retrofit is possible and how hard it would be to install or if a dealer can do the retrofit. I got a Vw and the dealers are usually hesitant and not willing to retrofit certain things
LexusLx570
LX - 3rd Gen (2008-2021)
23
09-19-16 09:02 PM
sheriffwoo
11-05-13 05:06 PM
