Sticky valve when cold?
We just purchased a 2007 ES350 as a Certified Pre-owned vehicle with 49,700 miles. When we drove it off the lot the car looked and sounded great. The engine was up to operating temp and sounded great and had plenty of power. We have had the car for one week and I have had several opportunities to drive the car with the engine cold and it has a noticeable tapping noise when under load until the engine is fully warmed up. It pretty much dissappears by then. By best guess is that it is a sticky valve or lifter. Is this common or do I have a problem? The car is still under another 3 years of warranty. Any comments will be much appreciated.
Do a search here for engine noise and you'll find A LOT of information and speculation as to what causes the engine noise in many '07's. It's a pretty common issue with a lot of them. There doesn't seem to be any fix and I haven't heard of any engine failures etc., associated with it.
Just to be safe, be sure to bring it up when you have your car in for any work. It can't hurt to have your concern entered on the service record.
This is not something to worry about. I've had my 2007 since new. I purchased it in November 2006. It has made this ticking sound when cold from day one. It goes away after a few minutes. It does not affect performance. My car has been perfect. No issues at all. This is just an idosyncrosy of the car. Enjoy your ride.
This is not something to worry about. I've had my 2007 since new. I purchased it in November 2006. It has made this ticking sound when cold from day one. It goes away after a few minutes. It does not affect performance. My car has been perfect. No issues at all. This is just an idiosyncrasy of the car. Enjoy your ride.
Most likely a lifter. They can be changed out and are fairly inexpensive but labor will prob be expensive. Pretty much all overhead cam engines with hydraulic lifters end up with this noise. The lifters have to pump up with oil. They drain overnight and on cold starts the oil is thicker too. Once pumped up there shouldn't be a problem. You can try using a conditioner like transvalve fix. I noticed on one of my cars using mobil one seemed to make it worse and thicker oil will too. The stealership may tell you it's the injectors firing hard too I think that's bs if you have a noisy injector it doesn't go away.
I will change the oil this weekend to Castrol Synthetic. I have been using Synthetic in all of our cars for over 20 years and I am a big fan. It may help or solve it but will be better overall IMHO for the engine. If it is a lifter or two or even more that is not pumped up when cold, which sounds very plausible, then the synthetic will probably not change it at all. Unless the reason is the oil is thick enough when cold that it takes engine heat to thin it to make it through the small orifices in the lifters. If that is the problem the synthetic will almost certainly help because it stays fairly thin even when cold. I am in So. Cal. Mornings here in winter can get down to mid 30's until the sun is coming up then temps climb fast as in the desert. I will post again after the oil change if anything changes. Thanks to all who have responded. It's obvious I am not alone with this issue.
From what I read the new 3.5 has rockers and hydraulic lifters. This means no adjusting. The hydraulic lifters are self adjusting. It would mean that most likely on startup if there's ticking it's a dirty lifter that needs to pump up. I'd say only thinner oil will help the problem. Maybe goto 0w 20 synthetic. Most likely your still going to hear it. My eclipse had dirty lifters for a long time. The only thing I notice is on a cold start it can be a little rougher. I bought a new set of 16 for like 79 bucks and swapped them and not more noise at all end of story. No oil change or anything is going to fix it the only thing inwould try is trans valve fix from blaster. You could try putting some tranny fluid in the oil also.
Hi had the same issue just had the valve spring recall done and also mentioned the start up ticking so at the same time they replaced all valve lash adjusters. Noise gone they also swapped out the cam gears for that other start up noise. Hope all stays good for a while but was told minor ticking sound will not hurt engine in long run. If it gets very loud then that will cause something to wear out or break.
Although it sounds like a lifter, it is most likely piston slap, but probably in only 1 cylinder due to a piston having a tad too much clearance even after heat expansion. It would need a new shortblock at this point.
Let us know what happens.
You also have typical forged piston slap, but it's considered normal if it goes away within 2-3 minutes.
The piston slap in our van lasted for 15-20 minutes, but if you pulled next to a building you could always hear it.
Toyota just replaced our shortblock and no more noise.
https://www.clublexus.com/forums/es3...ing-fixed.html
