need help removing cover on rh side mirror
My mirror cover on my 2007 ES350 Rh side view mirror is cracked and I would like to replace it, the inner parts are fine its just the outer shell that needs to be replaced, but I need some help on how you take it off and replace the new shell on....thanks
tyleres (11-28-23)
I have the same situation, the outer cover broke and I was able to get a used unit on ebay. I understand there are 4 screws behind the mirror that hold the 2 covers, so you donot have remove the whole mirror from the door (painful option). So it is kind of easy.
My problem is I need to know how the mirror is connected and how to remove/pull it ? is there a tape holding it ? ... 4 clips that needs pulling out ?
It turns out that, yes, you can just remove the mirror itself from the unit without messing with the door.
There are four claws at the top & bottom of the mirror that hold the glass to the backing. Tilt the mirror all the way up and use a moulding remover to disengage the two bottom clips. You'll be able to slide the glass up and away.
The installation is the reverse of this.
I don't know anything about replacing the cover at this point.
With help from Dreyfus's instructions I was able to remove the mirror and replace the broken back and frame which I got from Ebay. My mirror did not need replacing. In the picture I show the 4 screws that open the whole case including the floor light. To remove the mirror follow Dreyfus's intructions.
thanks, this is really useful! i left my es350 parked outside and somebody decided to pry the mirror open ripping the the back (white plastic mounting mirror to the housing) ... curious if anyone has any luck replacing this?
