Scratches on dashboard/console
What's the best way to remove some fine scratches from the dashboard and center console. Is there any product that can safely be used to remove them?
I don't believe that there is a fine scratch remover for the dashboard since you will remove the luster coating and make the grain uneven and worst.
I do have some light scratch marks and use Eagle One interior cleaner and enhancer, it makes the dash darker and blend the scratches to fool the eye. I've used Simonez also with good result. I prefer anything that don't leave an oily film, just a bit.
I do believe that you can blend light coat of paint with an AIRBRUSH as i have one and it could be done since the color is doll, a few spray passes are enough.
jlgaustin
10-18-09 07:21 PM
