Replacing Non-Nav Radio in a 2007
#76
Well, even if the stock mic didn't work well with the head unit, you could use the same wires to hook up the radio's mic in that stock spot. Again, you're right - would be a little bit of a pain to run new wires,
Also - checked with a local installer here, Metra JUST came out recently with the ES330 kit - installer's wife has one. He said they're typically behind, especially for the really custom dashes. Kind of a shame.
#77
It's not much. Those spacers are about 1/2" deep and they barely give my speakers enough clearance.
The original speakers go about 1 1/8" into the door. I checked my documentation and the PG speakers have a 73mm mounting depth. Here are my adapters - http://www.amazon.com/Scosche-SAT69-...7240923&sr=8-3 If you are going with 6x9 speakers, you will need something like this - http://www.car-speaker-adapters.com/items.php?id=SAK008 .
If you know, is it possible to use the existing wiring for the speaker on the rear deck to drop down into the trunk so an external sub could be easily connected? I like that box you got at Wal-Mart and would like to do something similar.
TIA!
#78
I'm looking at beginning with the door speakers. I have read your entire thread and just want to be sure, if I want to replace either the front or rear door speakers I will need one of thHe above-mentioned adapters plus one set each of the Metra Toyota Speaker Adapter Plugs (one set for the F&R) you reference in post #36? This allows one to install either 6.5's or 6x9's in either location?
The adapters I chose allowed you to put 6.5" speakers in a 6x9 opening. Based on the depth, I would think you will still need a spacer if you go with a 6x9 speaker.
You did not mention changing out the tweeters. That's the biggest upgrade. By going with component speakers, I removed the highs from the door speakers and routed them to the dash tweeters as they should have been in the first place.
#79
Thank you for the reply.
When I go back I now see your 6.5" mounted which looks nice. I suppose I would be interested in doing something like that, which means I would need the adapters I referenced in my previous post (the ones you are using) for the front and the others (6x9) for the back plus the fore-mentioned wiring harnesses and possibly a spacer for the rear doors, correct?
I am not planning on doing the tweeters in the dash.
I have access to a powered subwoofer that I would like to try if the wiring would drop down from the existing sub, but I'm guessing I will need to get power from somewhere?
I am curious to know what it will sound like with only pulling the four door panels and doing some re-wirng in the trunk rather than replacing all 7 speakers, running a new amp (amps?) and having to pull the HU, all of which I am willing to do just not at this time due to the fact that I'm not certain just how much longer I will own this car.
#80
#81
My other car had a set of components in the front similar to this one, I replaced the door speakers (6.5") with Infinity Kappa 62.9i but left the OEM tweeters in place and am very happy with the results.
Let's say just for fun I decided to go with a mix of your suggestions and what I was thinking of by swapping out the front door speakers & dash tweeters with a component set, the rear door speakers with a set of 6x9's and my aforementioned powered sub. What exactly would you say I would need to complete the swap besides the speakers of course.
Thanks again!
Thanks again!
#83
@Robert_J; Thanks for all of your information and input.
Today I completed most of the swap by getting the speakers changed out, amps added and a subwoofer to the trunk. I have an iPod controller kit but didn't get around to removing the dash, maybe next week.
I just have to say that I am completely blown away by the new system and am finally - after 5+ years - satisfied!
New Stuff:
JLC3-650 (x2 -f&r)
JL10W3
JLXD400/4
JLXD600/1
Sub/box:
![](http://i50.tinypic.com/10ohao1.jpg)
Amps/etc. behind sub:
![](http://i45.tinypic.com/fuvrtl.jpg)
Old crap speakers:
![](http://i48.tinypic.com/ezhub.jpg)
Thanks again!
New Stuff:
JLC3-650 (x2 -f&r)
JL10W3
JLXD400/4
JLXD600/1
Sub/box:
Old crap speakers:
Thanks again!
#85
This is my first experience with JL and I am overly satisfied!
Just an update; swung into Best Buy and took a look at the iPod interface kit and decided to proceed since they had time to do the install while I waited. After about a half an hour and some minor troubleshooting, all was well and I now have complete control over my iPhone at the radio/steering wheel, a line-level input and charging ability all in one connection! Very happy indeed.
#87
https://www.clublexus.com/forums/es3...-thread-4.html
