Need help with coolant part
So i had a leak and when i went to check i saw what the problem was. The problem now is when can i get this peice and what is it called. Im dont know much past basic stuff on the motor. Please help me out i need to fix this asap heres pics of what im talking about.
Well before I'd spring for a new radiator I'd get one of those double-syringe tubes of 5 minute expoxy. I'd mix the whole thing at once and glue the bejeezus out of that cap. It doesn't need to be pretty, just water tight. It should hold if you roughen up the areas you're sealing with sandpaper first.
If it leaks again then you're only out the $5 for the glue (well, plus any new coolant).
well i did some ghetto **** for now lol i put zip ties in angles to hold it down and applied jb weld over it, its still leaking a tad bit because it hasent fully dried but they are litterally tiny drops. my coolant tank hasnt even lost fluid. i put it on like at 12am last night but still kinda gooey. i will apply more tonight when im not driving and i think its a fix vs a radiator
so my radiator has done well since this fix i did in september, but its giving out now. how much is this gujnna cost me to replace the radiator i guess? please anyone with info let me know the cheapest route times are ruff! thanks!!
A quick look at online shows a range from $159 to $247 for an ES350 radiator with free shipping.
It looks like either a blow out plug or something needed for the injection mold of the part. It also can be for another radiator application. I would go to a radiator shop and see what they suggest. Either the plug is welded or press fit so they should know how to repair it.
