ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
sealed transmission maintenance
Old 04-22-12, 04:38 PM
  #31
tolian21
tolian21's Avatar
how do you get it done? From what I can tell the dealer will turn your request down, and I would never go elsewhere for something important as transmission... especially if they don't how to do this complicated procedure or will use wrong ATF fluid.
Old 04-25-12, 07:06 AM
  #32
frankbcnt
frankbcnt's Avatar
Dealer, a trusted machanic or a transmission place.
The ppl outside the dealership have good info too from systems like all-data and snap-on shop key. I have access to both and all-data is very detailed. It comes down to who you trust.
I'm the opposite with the dealerships. I don't trust them with anything. I do mostly everything myself and have for years. If there's something I can't figure out or don't have time I have alot of trusted people I know in the business. I just can't stand that separation of talking to the guy working on my car and having to talk to a damned service writer BS. Even if some of them are hot little blondes . If the service writers don't drive the cars themselves and get involved then what use are they. They don't do that anymore and any of the dealerships around
Here!
So even if the oil and maintinenece is free (my tundra) I don't even go.
Old 05-02-12, 10:24 AM
  #33
wpbmed
wpbmed's Avatar
Service writers are CLUELESS! The are not mechanics, usually have no idea about cars, and are only there in that position because they can be nice to people. NEVER listen to what they say. Do what the last poster said, ask around and find someone you trust.
Old 05-02-12, 11:06 AM
  #34
oldgrump
oldgrump's Avatar
If you want to have a technical question answered then tell (nicely) the service writer that you'd like to talk to the shop foreman or one of the lead mechanics. A reputable (and smart) dealership will have no trouble with this. If they balk......then move on. And don't forget.......that the only person that is LESS knowledgeable than a service writer is usually the Service Manager!
Old 05-02-12, 01:30 PM
  #35
LexBob2
LexBob2's Avatar
I've found that service writers and service managers are just like any other job. Some good, some bad and some mediocre. They're not all bad and not all good. You meet all kinds and live and learn.
Old 05-30-12, 02:08 AM
  #36
chuyrobles
chuyrobles's Avatar
Originally Posted by frankbcnt
yes
its a long process but drain the pan, a quart will come out. Add a quart to the fill hole. Take off the cooler line closest to the drivers side, attach a hose to the radiator and have someone start the car and pump the fluid into a 2 1/2 quart painters bucket and a soon as you hear air have them shut it off. 2 quarts will come out (sometimes a tad over). Pour 2 quarts in and repeat till 11 quarts are out and 11 quarts are in (2 at a time of coarse). Add a half quart more in the fill and start the car. Make sure it is level either on a lift or get a level and level the car. Get a temp gun and wait till its 104-113 degrees on the pan and open and drain the pan while its running (yea sounds weird) until it slows to a trickle (about a half quart comes out) and quickly put the pan plug back in and tighten. turn the car off and add 200ml and your done.
No filter?
Thanks for the write-up. My Taco is also sealed.
Old 05-30-12, 06:50 AM
  #37
frankbcnt
frankbcnt's Avatar
There is No filter
Universe93
ES - 6th Gen (2013-2018)
09-23-17 01:23 PM
bhaubold
57
08-22-16 10:03 PM
gebo
Maintenance
02-19-16 09:52 AM
DplanDman8
15
05-04-13 10:09 PM
surferbum
RX - 3rd Gen (2010-2015)
09-26-11 09:43 AM
Quick Reply: sealed transmission maintenance
